How to create relationship between diff data sets
Dear Experts,
I want to create basically 1 pivot table which can summarize my all KPI's .for example-spend,quality and delivery to be combined in one pivot table.How can we do that,i tried using power pivot and created separate tables for region,month (unique) and linked to the kpi data but still i don't get the desired result.can we achieve using power pivot,if yes then what is the right approach(how to establish join) or any other simple method.
pivot table should look something like "pivot" tab in the attachment.
Note:this is test data but actually each kpi would go around 5 lac records.So performance and memory is also one of the aspect I'm looking.
Your help is always appreciated.
Thanks in advance.
  • chandoo-test.xlsx
Hi Tomas,
Yes exactly,also if i include other fields from pivot like plant name,commodity name the numbers should come correctly.
How you did that?Is it possible?
Please share...
Thanks,
