eddyrcabrera79
Attached is the sample Userform I'm working on it. It works perfect. all the information in being transfer to the excel document.
the Help I required is:
Once all the fields in the user form are filled, I press OK and I receive a display message "One record written to Sheet", I press OK and another display message comes up, "Do you want to enter another record?"
1 - After pressing "Yes" how can I make all the fields clear up in the Userform, in order to start inputting new information?
2 - In case one or more fields are empty because no data was input on them, How can I make a display message appear when I press the OK Bottom saying " Please check blank fields"
Please if you can make the corrections in the CODE and let me know by putting a comment what was added or what was included. I just want to see what the solution was to learn
Thanks in advance
Thanks in advance
