How to Email a Range which contains a chart using VBA?
sreekhosh
I am using the below code for sending a range as email body. But I recently added a chart also into the range but it doesnt work (chart is not displaying).
I just try with disabling the following code in function [.DrawingObjects.Delete ]. then the an error message was displying in email body instead of Chart. Please help.
Please see the code below
Sub Email_Send()
Dim rng As Range
Dim OutApp As Object
Dim OutMail As Object
Set rng = Nothing
Set rng = Selection.SpecialCells(xlCellTypeVisible)
Set rng = Sheets("Email").Range("A1:W43").SpecialCells(xlCellTypeVisible)
On Error GoTo 0
If rng Is Nothing Then
MsgBox "The selection is not a range or the sheet is protected" & _
vbNewLine & "please correct and try again.", vbOKOnly
Exit Sub
CurrentFile = Left(ActiveWorkbook.Name, (InStrRev(ActiveWorkbook.Name, ".", -1, vbTextCompare) - 1))
With Application
.EnableEvents = False
.ScreenUpdating = False
strbody = "<H5>Dear Team,</H5>" & _
"Please find the " & CurrentFile & "."
With OutMail
.to = Range("x1")
.CC = Range("x2")
.BCC = ""
.Subject = CurrentFile
.HTMLBody = strbody & "
" & RangetoHTML(rng) & "
" & Signature
.Display
On Error GoTo 0
With Application
.EnableEvents = True
.ScreenUpdating = True
Function RangetoHTML(rng As Range)
Dim fso As Object
Dim ts As Object
Dim TempFile As String
Dim TempWB As Workbook
TempFile = Environ$("temp") & "/" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
'Copy the range and create a new workbook to past the data in
rng.Copy
Set TempWB = Workbooks.Add(1)
With TempWB.Sheets(1)
Cells(1).PasteSpecial Paste:=8
.Cells(1).PasteSpecial xlPasteValues, , False, False
.Cells(1).PasteSpecial xlPasteFormats, , False, False
.Cells(1).Select
.DrawingObjects.Visible = True
On Error GoTo 0
'Publish the sheet to a htm file
With TempWB.PublishObjects.Add( _
SourceType:=xlSourceRange, _
Filename:=TempFile, _
Sheet:=TempWB.Sheets(1).Name, _
Source:=TempWB.Sheets(1).UsedRange.Address, _
HtmlType:=xlHtmlStatic)
.Publish (True)
'Read all data from the htm file into RangetoHTML
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
RangetoHTML = ts.readall
ts.Close
RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", _
"align=left x:publishsource=")
'Close TempWB
TempWB.Close savechanges:=False
'Delete the htm file we used in this function
Kill TempFile
Set ts = Nothing
Set fso = Nothing
Set TempWB = Nothing
End Function
Hi, sreekhosh!
I haven't ever tried to do such a thing, but at a first glance I think I'm afraid that you couldn't do that. The RangetoHTML variable is assigned the result of an open as text stream file, I can't imagine how to assign a chart to it. And if I could, I don't know how the .HTMLBody property would behave.
Hope it helps.
Regards!
Thanks SirJB7
Yes SirJB7, you are right it is not as simple as i expected. Today i tried another method, I saved the chart as JPG in a folder. and added to the HTML body (using <img Src="chart.jpg">). It works fine and displayed in the email but the thing is when ever i change the picture it will change in the email also.
Sreekhosh
Hi, sreekhosh!
Well, glad you found a workaround, even if not perfect. Welcome back whenever needed or wanted.
Regards!
Hi Sreekhosh ,
Have you checked out the following links ?
1. http://www.mrexcel.com/forum/excel-questions/42480-send-chart-email-body-visual-basic-applications.html
2. http://www.pcreview.co.uk/forums/include-excel-charts-outlook-email-body-vbulletin-t3580457.html
3. http://www.ozgrid.com/forum/showthread.php?t=62502 ; there are other links in this thread.
4. http://stackoverflow.com/questions/10281016/how-to-send-an-embedded-image-in-email-from-excel
thank you Narayan.
sorry for the late reply.
I have already gone through these links... Adding a chart in the message body is very tough task.. I chnagd ma mind..:( and started to send that chart as attachement in JPG format.
Sreekhosh
Dear Deepak,
I have asked this doubt one year before. I am very glad to see your reply after one year, however the link you provided is not satisfying my query.
I need to add a Range and a chart to email body for sending (not as attachment). But its not possible for me and I add the range into email body and attached the chart as well.
Sreekhosh
tested.
this will paste the active chart to mail body.
Sub CopyAndPasteToMailBody()
    Dim mailApp, mail As Object
    Dim olMailItem, wEditor As Variant
    Set mailApp = CreateObject("Outlook.Application")
    Set mail = mailApp.CreateItem(olMailItem)
    mail.Display
    Set wEditor = mailApp.ActiveInspector.wordEditor
    ActiveChart.ChartArea.Copy
    wEditor.Application.Selection.Paste
