How to protect range and share the workbook post protection
ThrottleWorks
I am using below mentioned code to protect range.
However it is not working. Cells are not getting locked even after using this code.
Can anyone please help me in this.
Sub MyProtect()
    'Code for protecting cells
    Dim CodeSht As Worksheet
    Dim TempLr As Long
    Set CodeSht = ActiveWorkbook.Worksheets("TAB")
    TempLr = CodeSht.Cells(CodeSht.Rows.Count, 1).End(xlUp).Row
    Dim TempRng As Range
    Set TempRng = CodeSht.Range(CodeSht.Cells(1, 7), CodeSht.Cells(TempLr, 10))
        ActiveWorkbook.ExclusiveAccess
        TempRng.Locked = True
        TempRng.Protect Password:="pass"
    On Error GoTo 0
Good!
Next -
select that range from sheet by add tmp line
TempRng.Select
before
and
check, that range can select!
= run Your code row-by-row
@vletm sir, I am only using the code mentioned above.
Sub MyProtect()
    Dim TempLr As Long
    On Error GoTo 0
ThrottleWorks - okay..I still tested that Your 'code':
1) How did You check... noticed 'not working'?
2) TempRng.Protect Password:="pass" cannot work! after fix, it works!
3) why use
ActiveWorkbook.ExclusiveAccess ? Shared file? Really need?
4) I made 'few' modifications and You would check this .. or not?
Sub MyProtect()
    With Sheets("TAB")
        If .ProtectContents Then Unprotect Password:="pass"
'   maybe next line no need ... who knows?
        If ActiveWorkbook.MultiUserEditing Then ActiveWorkbook.ExclusiveAccess
        .Range(.Cells(1, 7), .Cells(.Cells(.Rows.Count, 1).End(xlUp).Row, 10)).Locked = True
Hi @vletm thanks for the help. I am checking your code and will get back to you. Have a nice day ahead. :)
PS - I am not allowed to upload files. Apologies.
Hi @vletm sir, sorry for late reply.
Checked your code, however, code is still locking entire worksheet.
I want lock specific range only. Could you please help if you get time.
ThrottleWorks
1) I did many questions ... no answers!
2) PS - I am not allowed to upload files. Apologies. - I see!
3) Checked your code, however, code is still locking entire worksheet.
NO, If ranges A2:F10 and K2:O10 are DEFAULT LOCKED then
what will happen during protection?
Answer is those ranges will LOCK too!
'My Code' works ONLY with that specific range!
  • Book1.xls
