    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
How to return all rows with matching wildcard criteria
Discussion in 'Ask an Excel Question' started by Finny99, Apr 19, 2017.
  1. Finny99
    Finny99 New Member
    5
    I've been trying to get a formula to return all rows from a tab in which multiple criteria are met, including a wildcard criteria. I've attached the sample excel in terms of what I'm trying to achieve. It's very basic and not the actual dataset, but you get the idea. I can get it when the cells are exact matches, but not if the cell contains it.
    Please help if you can and thanks.
  2. AlanSidman
    AlanSidman Member
    90
    try this VBA solution:
    Code (vb):
    Sub FindText()
        Dim i As Long, lr As Long, lr2 As Long
        lr = Range("A" & Rows.Count).End(xlUp).Row
        Dim sFind As String
        sFind = Range("G2")
        For i = 2 To lr
            lr2 = Range("F" & Rows.Count).End(xlUp).Row
            If InStr(1, Range("B" & i), sFind) > 0 Then
                Range("A" & i & ":C" & i).Copy Range("F" & lr2 + 1)
  3. PaulF
    PaulF Active Member
    185
    I hope this helps you,
    I added a helper column with: =IF(AND(ISNUMBER(SEARCH($F$2,A2)),ISNUMBER(SEARCH($G$2,B2))),MAX($D$1:D1)+1,"")
    Then a lookup value built on an expanding array: =INDEX(A$2:A$5,MATCH(ROWS($F$6:F6),$D$2:$D$5,0))
    See attached.
    Respectfully,
    PaulF
  4. Nebu
    Nebu Excel Ninja
    2,008
    Hi:
    Use the following formula.
    =INDEX($A$2:$A$5,AGGREGATE(15,6,(ROW($A$2:$A$5)-MIN(($A$2:$A$5))-1)/MMULT(($F$2=$A$2:$A$5)*(IF(ISNUMBER(SEARCH("*"&$G$2,$B$2:$B$5))>0,1)),1),ROW(A1)))
    PaulF likes this.
  5. PaulF
    PaulF Active Member
    185
    I need to save this and rip it apart to learn and reply "I'm not worthy... " :)
  6. Nebu
    Nebu Excel Ninja
    2,008
    Hi:
    A small Correction
    =INDEX($A$2:$A$5,AGGREGATE(15,6,(ROW($A$2:$A$5)-MIN(($A$2:$A$5))-1)/MMULT(($F$2=$A$2:$A$5)*(ISNUMBER(SEARCH("*"&$G$2,$B$2:$B$5))),1),ROW(A1)))
    Yon can take out the If condition from the Isnumber/ search condition.
  7. Finny99
    Finny99 New Member
    5
    Thanks everyone for the suggestions. I'll give them a shot. You all rock.
  8. Finny99
    Finny99 New Member
    5
    how do I enter this formula? I was trying to edit it and then drag the formula across, but it doesn't return the same values as are in the cells. Sorry for the stupid question. Also, I switched the selection from New to Old and it returned both of the rows for OLD but it shouldnt' do that.
  9. Nebu
    Nebu Excel Ninja
    2,008
    Hi:
    It works fine at my end here the file where I switched the selection from New to Old and it returned only one row for OLD.
  10. Finny99
    Finny99 New Member
    5
    How do I manage this formula? I try dragging across to more cells and it ceases to work properly. Is there something special?
  11. Finny99
    Finny99 New Member
    5
    nevermind. I noticed the formula had locked cells in the first piece which weren't moving when being dragged. THanks again.
  12. bosco_yip
    bosco_yip Well-Known Member
    1,043
    In addition to remove the "$" sign near INDEX, MMULT function and "*" also can take out.
    and, become >>
    =INDEX(A$2:A$5,AGGREGATE(15,6,(ROW($A$2:$A$5)-MIN($A$2:$A$5)-1)/($F$2=$A$2:$A$5)*ISNUMBER(SEARCH($G$2,$B$2:$B$5)),ROW(A1)))
  13. Nebu
    Nebu Excel Ninja
    2,008
    Hi:
    Its ok to take out "*", but if you take out MMULT , the order in which the Output are shown will be in reverse.
  14. bosco_yip
    1,043
    1] The output reverse problem can be fixed by changing a "*" into "/" as in :
    =IFERROR(INDEX(A$2:A$5,AGGREGATE(15,6,(ROW($A$2:$A$5)-MIN($A$2:$A$5)-1)/($F$2=$A$2:$A$5)/ISNUMBER(SEARCH($G$2,$B$2:$B$5)),ROW(A1))),"")
    2] A comparison formula file is herein attached
    Thomas Kuriakose likes this.
Share This Page
