    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
How to write and call functions from a module
Discussion in 'VBA Macros' started by ThrottleWorks, Jan 10, 2017.
  1. ThrottleWorks
    ThrottleWorks Excel Ninja
    1,616
    I hardly use functions in my coding. However I want to learn how to write functions and call from module.
    Can anyone please share links which will help me understanding functions. Thanks.
    Please see below example for your reference.
    Code (vb):
    Sub File_Select()
    Call FilePicker(Sheet1.TextBox1)
    Sub FilePicker(ByRef txt As Object)
      With Application.FileDialog(msoFileDialogOpen)
    .AllowMultiSelect = False
      .Show
      If .SelectedItems.Count > 0 Then txt.Value = .SelectedItems(1)
  2. Hui
    Hui Excel Ninja Staff Member
    10,277
  3. Hui
    10,277
    Here is a basic example
    Code (vb):
    Sub List1()
    Dim i As Integer
    Dim j As Integer
    'Make a  table of i & i^2
    For i = 1 To 10
      j = square(i)
      Debug.Print i; j
    Code (vb):
    Sub List2()
    Dim i As Integer
    Dim j As Integer
    'Make a  table of i & i^2+10
    For i = 1 To 10
      j = square(i) + 10
      Debug.Print i; j
    Code (vb):
    Function square(myNumb As Integer) As Integer
      square = myNumb * myNumb
    End Function
    You can see that the first module List1 makes a list of integers between 1 and 10 and the square of each number
    It uses a function Square() to work out the square
    Because square is a generic sort of function that you are likely to use in other applications, it can be used as in List1, where the numbers and the squares+10 are printed
    ThrottleWorks likes this.
  4. Hui
    10,277
    For a sample where multiple values are sent to the function
    Code (vb):
    Sub List3()
    Dim i As Integer
    Dim j As Integer
    'Make a  table of i * j
    For i = 1 To 10
    for j = 1 to 10
      k = product(i,j)
      Debug.Print i; k
    Code (vb):
    Code (vb):
    Function Product(myNumb1 As Integer, myNumb2 As Integer) As Integer
      Product = myNumb1 * myNumb2
    End Function
  5. Marc L
    Marc L Excel Ninja
    2,916
  6. ThrottleWorks
    1,616
    Hi @Hui sir and @Marc L sir, thanks a lot for the help.
    Am going through this and will revert with details.
    Have a nice day ahead. :)
    PS - Was trying to post yesterday only. Somehow it was not done. Just was as auto-complete while referring post.
Share This Page
