Hi! I need some help with a task planner I have prepared. I have a data entry tab and would like that the tasks entered there are shown in a calendar. As there could be several tasks planned for the same day, and several people do to the same task the same day, I'm interested to see all the information in the same cell when needed.
I have built two formulas:
=IFERROR(INDEX(Summary;MATCH($A5;IF(C$4>=TaskStart;IF(C$4<=TaskEnd;Task));0));"")
This is looking the task in column A in the Calendar tab in the tasks table in Data entry sheet; it is fine, but if several people have planned the same task, the same day the formula returns only the first match
=IFERROR(AND(INDEX(Summary;MATCH($A8;IF(C$4>=TaskStart;IF(C$4<=TaskEnd;Task));0));"");IF(AND(WEEKDAY(C$4)>=1;WEEKDAY(C$4)<=7);
SUBSTITUTE(SUBSTITUTE(OFFSET('Data entry'!$J$3;LARGE(IF(C4>=TaskStart;IF(C$4<=TaskEnd;TaskNum;0);0);6);0)
"&OFFSET('Data entry'!$J$3;LARGE(IF(C$4>=TaskStart;IF(C$4<=TaskEnd;TaskNum;0);0);5);0)
"&OFFSET('Data entry'!$J$3;LARGE(IF(C$4>=TaskStart;IF(C$4<=TaskEnd;TaskNum;0);0);4);0)
"&OFFSET('Data entry'!$J$3;LARGE(IF(C$4>=TaskStart;IF(C$4<=TaskEnd;TaskNum;0);0);3);0)
"&OFFSET('Data entry'!$J$3;LARGE(IF(C$4>=TaskStart;IF(C$4<=TaskEnd;TaskNum;0);0);2);0)
"&OFFSET('Data entry'!$J$3;LARGE(IF(C$4>=TaskStart;IF(C$4<=TaskEnd;TaskNum;0);0);1);0)&"
";"0,";"");'Data entry'!$J$3&"
";"");"")&IF(COUNTIF(Holidays;C$4)>0;VLOOKUP(C$4;HolidaysColor;2;FALSE);""))
This is looking the task in column A in the Calendar tab in the tasks table in Data entry sheet; if there are several people with any task planned the same day the formula is returning all the tasks in the same cell, but I want that it returns only the people with one particular task planned for that particular day
Apologies for my very bad explanation/description of the matter!! I have attached the file, I hope it would be clear once you take a look on it.
Thank you so much and Regards!!
Raquel.
Raquel.
