iNDEX
shibulal
=IF(COUNTIF($A$4:$A$15,"*"&$D$7&"*")<COLUMNS($E7:E7),"",INDEX($B$4:$B$15,SMALL(IF($A$4:$A$15="*"&$D$7&"*",ROW($A$4:$A$15)-MIN(ROW($A$4:$A$15))+1),COLUMN(A1))))
Why do this formula giving #NUM!
Uploading sample file is better to find error
As Syedali said, a file would be helpful. There's nothing wrong with the formula structurally. However, I can guess what's wrong. While the COUNTIF function supports wildcards, the "=" in your IF function does not
...IF($A$4:$A$15="*"&$D$7&"*"...
This will look for a literal string containing asterisks. You would need to use the SEARCH/FIND to check. Perhaps like this?
=IF(COUNTIF($A$4:$A$15,"*"&$D$7&"*")<COLUMNS($E7:E7),"",INDEX($B$4:$B$15,SMALL(IF(ISNUMBER(SEARCH($D$7,$A$4:$A$15)),ROW($A$4:$A$15)-MIN(ROW($A$4:$A$15))+1),COLUMN(A1))))
