Insert Excel Formula via VBA code
Hi fellas,
I am working on a vba project and within it I want to insert a standard formula into a range. I have written but somewhere it is not working please help.
'call resolution time line update
Windows("ABG_2Hrs_Report_Automation_Tool_ver2.0.xlsm").Activate
Range("t2") = "=if(s2*24<2,""<2 Hrs"",if(AND(s2*24>2,s2*24<4),""2-4 Hrs"",if(AND(s2*24>4,s2*24<8),""4-8 Hrs"",if(AND(s2*24>8,s2*24<24),""8-24 Hrs"","">24 Hrs"")))))"
    Range("S1").Select
    Selection.End(xlDown).Select
    Range("K" & n).Select
    Range(Selection, Selection.End(xlUp)).Select
    Selection.FillDown
    Selection.End(xlUp).Select
You can refer to my code above. It is stopping at the 2nd line (Range("t2")........)
Can you try the below..and check if it works fine..
Range("t2").FormulaR1C1 = "=IF(RC[-1]*24<2,""<2 Hrs"",IF(AND(RC[-1]*24>2,RC[-1]*24<4),""2-4 Hrs"",IF(AND(RC[-1]*24>4,RC[-1]*24<8),""4-8 Hrs"",IF(AND(RC[-1]*24>8,RC[-1]*24<24),""8-24 Hrs"","">24 Hrs""))))"
Change to below code
Range("t2").formula = "=if(s2*24<2,""<2 Hrs"",if(AND(s2*24>2,s2*24<4),""2
Hey its working u r champion :)
but it is not dragging down :( .....I am trying to figure it out, if u saw any flaw in my code plz do suggest.
