insert picture position in word using excel VBA
jk51
Hi
I need help please on how to write coding correction part of the VBA excel program for inserting picture position in word 2010. I don't know how to write the absolute position with measurement syntax.
Here is what I need:
My picture size is H=12.75cm by W=19.32cm.
In MS Word page layout setting:
Horizontal
I want it 'Absolute position' = 3.15cm to the right of Page
Vertical
I want it 'Absolute position' = 3.44cm below Page
See my code below:
 Set aShape = wrdDoc.ActiveWindow.Selection.InlineShapes.AddPicture(Filename:=GraphImage, LinkToFile:=False, SaveWithDocument:=True).ConvertToShape
                With aShape
                        .Height = CentimetersToPoints(12.75)
                        .Width = CentimetersToPoints(19.32)
                        .Left = CentimetersToPoints(3.15)
                        .RelativeHorizontalPosition = _
                            wdRelativeHorizontalPositionPage
                        .Top = CentimetersToPoints(3.44)
                        .RelativeVerticalPosition = _
                            wdRelativeVerticalPositionPage
                        .Select
Thanks you.
Best
Mr Singh
Hi, jk51!
I don't understand why do you need Excel VBA code for modifying a Word file. And it's very difficult without both sample files, so consider uploading them.
Regards!
Hi SirJB7,
I am inserting a picture per page and there are about 80 pictures (map in emf) image. The image are all of the same size. My picture size is H=12.75cm by W=19.32cm.
I am trying to build a report generator using an excel database. I would like to insert pictures into word bookmarks.
The program is working when inserting per page but not in the correct position. All I need to know to modify the part of the VBA coding on how to write the absolute position with measurement syntax.
Horizontal
Vertical
It is a small procedure coding.
I will be grateful if anyone know how to translate this on absolute position with my measurement in vba excel.
Thanks.
Mr Singh
