Is it possible to match based on partial data in 2 fields
Jaimee001
Hi All,
I thought this would be easy but I'm not able to find anything. I have a report where 2 of the columns differ by just the first byte (?)
I00063 000063
Is there a formula that I could use to make a match on the bytes after the first one?
I've attahced an example report. Hopefullly, this all makes sense :)
I could do a text to column and then match but that would be adding addtional columns to the report.
Thank you in advance
Jaimee
  • match by certain number of bytes.xlsx
