    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
looking for a vlookup VBA code for my report
Discussion in 'VBA Macros' started by kittu akula, Mar 16, 2017.
  1. kittu akula
    kittu akula New Member
    22
    i am looking for a vlookup VBA code for my project.
    i have Multiple sheets llike sheet1,sheet2,sheet3,....upto sheet7 in these sheets i have different columns and a usernames column (column B) as common. i have one more sheet8 in same excel work book in that i have only one column with name usernames (with usernames at column A )
    now i want to vlookup sheet1 to sheet7 with sheet8 and what ever names are matching should be there in report and which are not maching with usernames in sheet8 should be deleted in all sheets from sheet1 to sheet7( i.e NA should be deleted)
    Please let me know if its possible with VBA code
  2. PCosta87
    PCosta87 Well-Known Member
    723
    Hi and welcome to the forum :)
    If you can, please upload a sample excel file with some dummy data so we can give you a more targeted answer.
  3. kittu akula
    22
    The sheets1-7 look like file1 and columns in sheet1-7 look like file2
    I need sheet1-7 vlookup with sheet8 (sheet8 look like file3)
    usernames which are matching should be saved and remaining which are not matching (i.e #N/A) in sheet1-7 should be deleted.
    sheet8 is only for vlookup purpose ...all data is available in sheet1-7
  4. karlbf
    karlbf New Member
    3
    Please upload a sample excel file with some dummy data and not jpg's
  5. kittu akula
    22
    pleas find attachment ... i have attached dummy data.. raw number may increase and decrease in sheet1-7 but sheet8 is fixed
  6. PCosta87
    723
    Here you go... (please refer to the attachment)
    Let me know if this helps.
    Thomas Kuriakose likes this.
  7. kittu akula
    22
    this works for me wonderfully ....want to know if lookup is done using column number or column heading ...because when i checked original data sheets in some sheets column B heading name is used differently like "Customer name" and as i mentioned in dummy sheets its "Username". i hope it will look according to the column number only.
  8. PCosta87
    723
    The code looks at the column 2 ("B") so there is no problem if the header is different. As long as the usernames are in "B" you should be fine.
    Also, the list in sheet8 must be in "A". If it isn't make sure to adjust the code to match.
    I'm glad I could help :)
  9. kittu akula
    22
    i am not getting correct data with this code
    can you see above there are still some names with #N/A , after running the code for cross verification i did the vlookup manually and found some names which are not matching still present in report
  10. PCosta87
    723
    I think I know what the problem is... try the following:
    Code (vb):
    Sub delete()
        Dim arr(), msg As String
        Dim ws_lrow, ws8_lrow, i As Integer
        Dim ws As Worksheet
        ws8_lrow = Sheets("Sheet8").Cells(Rows.Count, 1).End(xlUp).Row
        ReDim arr(ws8_lrow)
        For i = 2 To ws8_lrow
            arr(i - 2) = Sheets("Sheet8").Cells(i, 1).Value
        For Each ws In ActiveWorkbook.Sheets
            ws_lrow = ws.Cells(Rows.Count, 2).End(xlUp).Row
            For i = ws_lrow To 2 Step -1
                If IsInArray(ws.Cells(i, 2), arr()) = 0 Then
                    msg = msg & "User """ & ws.Cells(i, 2) & """ from: " & ws.Name & vbCrLf
                    ws.Cells(i, 2).EntireRow.delete xlShiftUp
        Next ws
        If Len(msg) > 0 Then
            MsgBox "The following users have been deleted:" & vbCrLf & msg
    Private Function IsInArray(valToBeFound As Variant, arr As Variant) As Boolean
        Dim element As Variant
        On Error GoTo IsInArrayError: 'array is empty
         For Each element In arr
                If element = valToBeFound Then
                    IsInArray = True
                    Exit Function
            Next element
        Exit Function
    IsInArrayError:
        On Error GoTo 0
        IsInArray = False
    End Function
    Since we are deleting rows, we need to go from bottom to top an not the other way around, otherwise the code will skip rows.
    My mistake, shouldn't have missed that :(
    It should be working now.
    Let me know if it isn't.
    EDIT: I've added a condition to show the message only if something was deleted.
    kittu akula likes this.
  11. kittu akula
    22
    it worked but showing type mismatch at
  12. PCosta87
    723
    Can you upload the file where is throws that error?... in the sample provided it works fine.
  13. kittu akula
    22
    when i tried with original data i got that message ....i will try once again and update you..can i insert some more sheets and do vlookup as in array there is no integer is mentioned?
  14. PCosta87
    723
    I'm sorry, I'm not sure I got this last part, but you can have as many sheets as you like, as long as:
    1. You keep "sheet8" as the name of the sheet where the list is, or
    2. If you change the sheet's name, change it in the code as well.
  15. Marc L
    Marc L Excel Ninja
    2,916
    Hi !
    Instead of using a worksheet name neither its index
    better is to use its CodeName as it does not change
    when worksheet is moved or renamed !
    [​IMG]
    Here for example for A1 cell of "abc" worksheet
    you can use Sheet1.[A1] or Sheet1.Range("A1")
    instead of Worksheets("abc").Range("A1") or Range("abc!A1")
    PCosta87 and kittu akula like this.
  16. kittu akula
    22
    Thanks all for the suggestions provided...its now working properly..
    this forum seems to be more active compare to other
    keep it up..
Share This Page
