Thomas Kuriakose
Respected Sirs,
We have two tabs receivables and payables for unit codes as in the attached file.
We need to match the unit code of receivables with the corresponding unit codes of payables based on the voucher number.
It is possible that one receivable unit code has multiple payable unit codes based on the voucher and vice-versa.
I tried a pivot table ,but could not get the correct result.
Kindly suggest the correct way to get the result.
Thank you very much,
with regards,
thomas
with regards,
thomas
