lookup unique text values with criteria
Sandesh s
Dear friends
Need your help to easy my workload.
I have attached the example query. Plz help me to solve it..
Thanking...you in advance
Sandesh s
  • lookup for unique data with specific criteria.xlsx
Dear narayan
Thank you for the formula. But its invisible whenever i select and entered that cell. I will be very good if you please give me the formula which will not go invisible after entering the cell.
Thanking you
Sandesh s
I am not able to understand your problem ; can you please explain which cell you are referring to , and what the problem is in that cell ?
Dear narayan
Whenever i go to cell no a25 Or b25press f2 cell and entered it will cell value get invisible.
plz request you to give formula in which the result will be fixed.
Sandesh s.
Dear narayan
Sandesh s.
That is happening because the formula in the cell is an array formula , which has been entered using the key combination CTRL SHIFT ENTER.
Once you press F2 to go into EDIT mode , you should either press the ESC key to exit , or press the key combination CTRL SHIFT ENTER to enter the formula once more and exit. If you press only the ENTER key , the formula will not be correctly entered , and the cell will display a blank.
Dear narayan.
Its request if you could give some fixed formula. As there is lots of person who will handle this excel sheet and there is more possibility of changes in the sheet.
Sandesh s
Wow thanks for this formula....its working as i want.
I will be more obliged if you could help me out in adding more criteria for which i added the sample file.
Really thank you if you could help me out.
Sandesh s
  • lookup for unique data with specific criteria - updated query.xlsx
Dear narayan thank you very much for your support.
But i have one question. Can i add more criteria for lookup the code . I.e. if i want to add the condition that it should lookup the code if the realisation date is greater or blank to the current criteria
Thank u in advance.
Also i would be more obliged if you explain how you creat the formula from your excellent mind.
thanks dear
Sandesh s
Dear friends.
Please help to improve the formula. Thanks to narayan for original formula.
Need your help in improving.the formula. Attached query for your references.
Sandesh shinde
  • lookup for unique data with specific criteria - final query.xlsx
Dear narayan.
Thanks for email. In ref. result should be - lookup those id number where ever reconcilation date is blank ( earlier than bank date) and reconcilation date is greater than bank date.
Thank you in advance.
Sandesh s.
Dear narayan
Sorry for delay in uploading the example.
I have attached example file for your reference.
Thanks in advance.
Sandesh s
  • lookup for unique data with specific criteria - final Final Query.xlsx
Just a clarification required ; you have written this :
Transaction of bank dated 01.01.2011 which was realised in earlier date than 01.01.2011
But these are transactions realized on 01.01.2011 , whose cheques were dated earlier than 01.01.2011.
Can you clarify ?
Dear it is just an example. To show the values in the specific result example date of 01st january 2011 i have create the bank dates of 30th and 31st jan 2011 in data sheet , and showed the realisation date of 01st january 2011 In some of the realisation column
Hope this will clerify your doubt.
Thanks...
Sandesh s
Dear narayan.
I have put the id code and figure in result sheet ( for dated 1st and 5th) manually. Please help with the formula which can lookup these data automatically. For that you can put the formula in date 7th jan 2011 in result sheet.
Thanking you
And i know you will find the formula with your expert mind.
Sandesh s
Hiii,.
See if is OK ?...formula OK for condition 1 ...if is it OK ...please let me know ...
Rahul shewale
