    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Macro for Formatting Charts
Discussion in 'VBA Macros' started by Colin Mannion, May 11, 2017.
  1. Colin Mannion
    Colin Mannion Member
    51
    HELLO
    I have a large number of charts where i need to update the format e.g. remove borders, change fonts etc.
    Have tried to put together a quick macro based on something I found online but it hasn't worked - see file attached - you can see I am a novice at this.
    Sub Update_Chart()
    Dim cht As ChartObject
    Dim sht As Worksheet
    For Each cht In sht.ChartObjects
    cht.Activate
    Active.Chart.Line.Visible = msoFalse
    Next cht
    CurrentSheet.Activate
    If anyone has a quick solution for this, it would be appreciated :)
    Thanks in advance.
    Colin
  2. PCosta87
    PCosta87 Well-Known Member
    870
    Hi Colin,
    Try the following:
    Code (vb):
    Sub Update_Chart()
        For Each cht In ActiveSheet.ChartObjects
            ActiveSheet.Shapes(cht.Name).Line.Visible = msoFalse
        Next cht
    Hope this helps
    Thomas Kuriakose likes this.
  3. Colin Mannion
    51
    Hi PCosta
    Thanks for this.
    It seems to do it for the first chart and then stop.
    Colin
  4. PCosta87
    870
    Oh yes, I forgot :)
    You have all charts with the same name... make sure all charts have a different name and you are good to go.
    If they are created one after the other Excel automatically does it for you but, since you probably did copy/paste of Chart 1, it seems they all ended up with the same name.
    Colin Mannion likes this.
  5. Colin Mannion
    51
    Aha!!
    Appreciate that PCosta :)
    Colin
  6. PCosta87
    870
    You are welcome :)
  7. Colin Mannion
    51
    HI PCosta
    Hope everything is okay with you.
    I have tried to build on that macro you kindly put together for me, so I can change several chart attributes at the same time. I recorded a macro with the actions required (removing gridlines and changing axes fonts) and inserted them into the middle section of the code you wrote, andf it is coming up with a debug error. Code is below - file is attached:
    Code (vb):
                ActiveChart.PlotArea.Select
                ActiveChart.Axes(xlValue).Select
                ActiveChart.Axes(xlValue).MajorGridlines.Select
                Selection.Format.Line.Visible = msoFalse
                ActiveChart.Axes(xlCategory).Select
            With Selection.Format.TextFrame2.TextRange.Font.Fill
                  .Visible = msoTrue
                  .ForeColor.ObjectThemeColor = msoThemeColorBackground1
                  .ForeColor.TintAndShade = 0
                  .ForeColor.Brightness = -0.5
                  .Transparency = 0
                  .Solid
                  .Visible = msoTrue
                  .Transparency = 0
                .Solid
        Application.CommandBars("Format Object").Visible = False
        Next cht
      .Transparency = 0
      .Solid
      Next cht
    Thanks in advance.
    Colin
  8. PCosta87
    870
    Try using the following:
    Code (vb):
    Sub Update_Chart()
            cht.Activate
            ActiveChart.Axes(xlValue).MajorGridlines.Format.Line.Visible = msoFalse
            With ActiveChart.Axes(xlCategory).TickLabels.Font
                .Size = 10
                .Color = xlThemeColorDark1
    '            .ColorIndex = 1
        Next cht
    It hides the Grid Lines and applies some formatting to the font of the category axis, in this case I've set the size to 10 and the color to the one on your code.
    You can either use Color or ColorIndex to change the color of the text.
    If you wish to remove the Grid Lines completely, you can also use:
    Code (vb):
    ActiveChart.Axes(xlValue).MajorGridlines.Delete
  9. Colin Mannion
    51
    Thanks for that PCosta - working a treat!
    Colin
  10. PCosta87
    870
    Don't mention it :)
  11. Debaser
    Debaser Active Member
    334
    FWIW, you don't need to select anything or turn events on and off for this:
    Code (vb):
    Sub Update_Chart()
            cht.ShapeRange.Line.Visible = msoFalse
            With cht.Chart
                With .Axes(xlCategory).TickLabels.Font
                    .Size = 10
                    '            .ColorIndex = 1
        Next cht
    Thomas Kuriakose and PCosta87 like this.
  12. Colin Mannion
    51
    Hi there
    I have a sheet which has a lot of charts many of which have the same name :-(
    Is there an easy way of renaming them to something unique so that macros will pick them up as different charts?
  13. NARAYANK991
    NARAYANK991 Excel Ninja
    14,669
    See if this is acceptable.
  14. Colin Mannion
    51
    Hi Narayan
    Thanks for this :) - the macro works great - I have now run into an other issue which I am hoping you may be able to help with.
    The plan is to loop through the charts one by one to apply some formatting changes - changing axes, borders, gridline etc.
    The macro I have coded for that generates an object error, which when cleared allows some of the steps to run. I can't quite work out what's going on - is there anything obvious to you?
    Appreciate the help.
    Colin
  15. NARAYANK991
    14,669
    See if this is OK.
Share This Page
