Macro to fill up pre defined colors for duplicates in single column
IKHAN
Hello
Found below macro to find duplicates in single column and highlight matching values, Issue with this macro is it uses only 1 color (red) and searches for duplicates in other columns
Require below pre defined colors to be added in below macro and search for duplicates in only single column.Fil up color based on change event.
Color= 4
color=7
Color= 12
color=38
color=39
color= 40
color=46
  Dim Rng As Range
  Dim cel As Range
  Dim col As Range
  Dim c As Range
  Dim firstAddress As String
  Target.Interior.ColorIndex = xlNone
  For Each col In Target.Columns
  Set Rng = Range(Range("A1"), Range("A" & Rows.Count).End(xlUp))
  Debug.Print Rng.Address
  For Each cel In col
  If WorksheetFunction.CountIf(Rng, cel.Value) > 1 Then
  Set c = Rng.Find(What:=cel.Value, LookIn:=xlValues)
  If Not c Is Nothing Then
  firstAddress = c.Address
  Do
  c.Interior.ColorIndex = 3
  Set c = Rng.FindNext(c)
  Loop While Not c Is Nothing And c.Address <> firstAddress
  Next col
  • test1.xlsx
Hi:
Find the attached.
Thanks for quick reply..
Help me modify
1.My Original data is in column D and sheet named "Plan"(Sheet 3)
2. Only predefined Colors to be used provided in list and option to add more colors if reqd.
3. In your macro - Colors change on new entry for previous entries.
4. When reqd. - It's better option for us to clear any color (no fill) for any cell.
Any help Please ??
My orIginal data in column D has dates/times to compare in format (ddd mmm dd,yyyy - hh:mm AM/PM - please see my previous post
Hi:
I am afraid I understood you fully. As far as the Column and sheet name is concerned change the range and sheet name in the code. I am not sure about predefined color, you mean to say that for each item in your list you have predefined a color? if you are not familiar with VBA you may have to upload an exact replica of your original file here.
Hi:
Hi : Have uploaded modified original file.
Macro provided doesn't work for dates/times in column D.
Really appreciate your help!!!
  • test.xlsm
@Nebu ...Dates and times are very often changed, Your solution doesn' if date or time is changed and new dups found
Try
    Dim r As Range, myColor, n As Long
    If Intersect(Target, Columns("a")) Is Nothing Then Exit Sub
    myColor = Array(4, 7, 12, 38, 39, 40, 46)
    Columns(1).Interior.ColorIndex = xlNone
    ReDim Preserve myColor(1 To UBound(myColor) + 1)
        .CompareMode = 1
        For Each r In Range("a1", Range("a" & Rows.Count).End(xlUp))
            If r.Value <> "" Then
                If Not .exists(r.Value) Then
                    Set .Item(r.Value) = r
                    If TypeOf .Item(r.Value) Is Range Then
                        n = n + 1: If n > UBound(myColor) Then n = 1
                        Union(.Item(r.Value), r).Interior.ColorIndex = myColor(n)
                        .Item(r.Value) = myColor(n)
                        r.Interior.ColorIndex = .Item(r.Value)
  • test1 with code.xlsm
@Nebu ..Have another worksheet change macro running in same tab, How do i combine both to run. please see attached
Macro currently running below:
Dim rngDV As Range
Dim oldVal As String
Dim newVal As String
If Target.Count > 1 Then GoTo exitHandler
Set rngDV = Cells.SpecialCells(xlCellTypeAllValidation)
On Error GoTo exitHandler
If rngDV Is Nothing Then GoTo exitHandler
If Intersect(Target, rngDV) Is Nothing Then
newVal = Target.Value
Application.Undo
oldVal = Target.Value
Target.Value = newVal
If oldVal = "" Then
If newVal = "" Then
Target.Value = oldVal & "; " & newVal
exitHandler:
  • testfile4.xlsm
The code I wrote should be in "4. Mobile" sheet, not the one you have Change event code, so should be OK.
Ok then try replace the whole code with the following
Private Sub Worksheet_Activate()
    Dim r As Range, a, i As Long, e, x
    With Sheets("2. Planning")
        If .Range("c" & Rows.Count).End(xlUp).Row > 12 Then
            a = .Range("c12", .Range("c" & Rows.Count).End(xlUp)).Resize(, 2).Value
    If IsArray(a) Then
            .CompareMode = 1
            For i = 2 To UBound(a, 1)
                a(i, 1) = Application.Trim(a(i, 1))
                If a(i, 1) <> "" Then
                    For Each e In Split(a(i, 1), ";")
                        x = Split(Application.Trim(e))
                        ReDim Preserve x(1)
                        .Item(Trim$(e)) = x
            a = Application.Index(.items, 0, 0): i = .Count
    With [d18:e18]
        .Resize(Rows.Count - .Row - 1).ClearContents
        If IsArray(a) Then
            .Resize(i).Value = a
    Worksheet_Change Range("d17")
    If Intersect(Target, Columns("D")) Is Nothing Then Exit Sub
    [d17].CurrentRegion.Columns(1).Offset(1).Interior.ColorIndex = xlNone
        .CompareMode = 1
        For Each r In Range("D13", Range("D" & Rows.Count).End(xlUp))
@ Jindon ..Was able to run earlier code provided successfully...I have few rows Highlighted row 1 to row 3 and when code executed ..it clears highlights in column D.
1. Can i maintain those highlighted rows ( row1 to row 3)?
2.Have same info in another tab in column D,can his be highlighted too for any dups as any changes done?
    If IsArray(a) Then
            .CompareMode = 1
                        ReDim Preserve x(1)
                        .Item(Trim$(e)) = x
    With [d18:e18]
        If IsArray(a) Then
        .CompareMode = 1
Uploaded file
Please see tab 2 , 3 ,4
To highlight dups in column D from line 13 in sheet 2 and sheet 3 column D
I'm totally lost...
Are you entering any data in col D of "4. Mobile" manually or via other sub routine?
If not, it should always have unique values?
I'm totally lost...
Entering data in "2. planning" in column D manually and also through formula
Column D = (=D13 or D14 or D15)
and also noticed that when duration changes in Column F and date\time changes ,it doesn't reevaluate column D and highlight duplicate accordingly.
See attached sample test file
  • testfile.xlsm
Guys.. Any suggestion.. Above code is almost there.just need minor tweaks.
Any change in column d ( enter new data, change thru another cell)in planning tab should re evaluate col D and update fill colours for dups in column d
