Macro to lock a workbook after a specific date
Indranil_Guha
Hello all Excel Ninjas,
I am trying to protect a work book so that no one can edit the file after a specific date and I would prefer to input that date in the macro instead of in a cell in the workbook. Could anyone please help me on this?
This simple example assumes that there is only a single sheet in the workbook and that macros are enabled. In a Standard Module enter:
Sub FreezeMe()
    Dim keyy As String, sh As Worksheet
    keyy = "obvious"
    Set sh = ActiveSheet
    sh.Unprotect Password:=keyy
        Cells.Locked = True
    sh.Protect Password:=keyy
and in the Workbook code area enter:
Private Sub Workbook_Open()
    If Date >= DateSerial(2015, 12, 25) Then
        Call FreezeMe
Is this.
PrivateSub Workbook_Open()
  If Date > DateSerial(2015, 12, 25) Then sheets("abc").protect 123
Sub FreezeMe()
    keyy = "obvious"
        Cells.Locked = True
        Call FreezeMe
Sub FreezeMe()
    keyy = "obvious"
        Cells.Locked = True
        Call FreezeMe
Thank you very much,
the codes is working and this solves my problem. but with this i faced a new one, could you please also help me to lock the coding page (if this is possible), as if anyone open the VB coding page the password is visible there and he/se can un-protect the sheet.
http://www.excel-easy.com/vba/examples/protect-macro.html
Hi..
How to protect entire column when date changes...
suppose i have data from A to G ..
A = contains cust name and Fro B to G contains date from 10-march-2016 to 16 march -2016
now i want to restrict column B when 10 march is over then when 11 march is over then column B & C restrict to change data...
how to do this...
