Making business invoice thr vba codes
arif
How to create business invoice thr vba codes
How to create vba codes for making business invoive where i put the number and all details related to that number are displayed
like see
1 Manojkumar
station
allahabad
2 Narendra
Fort
New Delhi
if i press 1 all details against 1 should be displayed plz show me vba codes and suggest how to run plz
Hi Arif,
Why do you need to go for VBA?
If you have all the details in a table or separate range or sheet, you can simple apply VLookup formula to acheive this. All you need to do is design your invoice and apply vlookup for fields that need to change based on input.
rest of the calculations like multiply, sum etc can be still in tact with simple formulas.
Upload an invoice you need to design with sample data of inputs.
Prasad DN.
Hi Arif,
Prasad DN.
Can u provide an example of this explanation plz sir thro sample workbook
Here is some basic invoice i downloaded from internet and made little changes.
I have added one sheet with all the details I need for invoice.
you need to enter the cust ID in cust ID cell like 1 or 2 or whatever you have created customer ids.
The rest of the information about that customer will be fetched from the table using simple VLookup formula.
I hope this is what you were looking for.
Prasad DN
  • BasicInvoice.xlsx
