Using below Macro to highlight duplicate date\time in column D- Works fine. Challenge i have is to find matching date\time in other column E and highlight with same color as column D.
Kindly Assist ...Thank You
Sub test3() ' Highlight dup times in col D
Dim r As Range, myColor, n As Long
Dim target As Range
Set target = Worksheets("TestPlan").Columns("d")
If Intersect(target, Columns("D")) Is Nothing Then Exit Sub
[d4].CurrentRegion.Columns(90).Offset(1).Interior.ColorIndex = xlNone
myColor = Array(4, 6, 35, 12, 15, 37, 38, 39, 40, 41, 46, 50, 53)
Columns(90).Interior.ColorIndex = xlNone
ReDim Preserve myColor(1 To UBound(myColor) + 1)
.CompareMode = 1
For Each r In Range("D4", Range("D" & Rows.Count).End(xlUp))
If r.Value <> "" Then
If Not .exists(r.Value) Then
Set .Item(r.Value) = r
If TypeOf .Item(r.Value) Is Range Then
n = n + 1: If n > UBound(myColor) Then n = 1
Union(.Item(r.Value), r).Interior.ColorIndex = myColor(n)
.Item(r.Value) = myColor(n)
r.Interior.ColorIndex = .Item(r.Value)
