saidhruv
Dear All - i have pdf file which i have converted into excel so that i can work with formulas. However, at times during conversion from PDF to Excel it seems some characters are either missed or replaced.
Is there a way to match the PDF with Excel?
Please note that if i copy data from PDF to Notepad, no characters are missed or replaced. However, the issue is i cannot put notepad data into the excel with the alignment which is same as PDF.
i am attaching the excel, pdf and notepad. Excel is created using www.pdftoexcel.com and thereby doing some manual alignment.
question1: is there a way i can match every character of pdf with the excel?
question2: is there a way i can convert notepad to excel with same alignment shown in PDF.
regards..
regards..
