DashboardNovice
In the attached file, I am getting a value of 4 for the MATCH function, which is returning he value in Column G. However, I would like to return a value of 5 which corresponds to column H.
Row 6 is my MATCH array, but this would work ask if I have the age range on row 4.
So for age 43, in cell D10, I should return $36,960 but instead I get $112,586. I tried adding one to the MATCH function, but this doesn't work if I use a number on the high end of any given column, e.g. if I use 40, instead of getting $112,586 I get $36,960. So adding one to the MATCH function doesn't work.
I tried using "-1" as the last argument and I get the #N/A error.
Any help would be greatly appreciated.
