Match with IF formula
Ferena
I am looking for a formula that calculates numbers differently based on the text in column A.
I need to have a summary calculation with multiple criteria for each employee ID. For every employee either External or internal rating will be provided.
If External data is avaialble, then the calculation should be (.7*external+.2*Self+.1*Internal) (ex. formula in column H11) If external data is not available then I would like it to be (.7*self+.3*Internal) (Ex.formula in column C11)
The challenge I am having is there are three rows for each employee ID, so I need to find a formula that combines MATCH and IF function.(or anything other formula that looks up employee IDs and then calculates based on the criteria)
I would like to get the result shown in row 11 and 12.
  • Book1.xlsx
Ferena
I would first recomend staying with a simple structured layout as you have provided
This allows a simple solution of:
C9: =IF(C4,(0.2*C2)+(0.1*C3)+(0.7*C4),(0.7*C2)+(0.3*C3))
C10: =IF(C7,(0.2*C5)+(0.1*C6)+(0.7*C7),(0.7*C5)+(0.3*C6))
But they are fixed for the rows
If you want a generic solution
C12: =IF(INDEX(C$2:C$7,MATCH($B12&"External",$A$2:$A$7&$B$2:$B$7,0),),(0.2*INDEX(C$2:C$7,MATCH($B12&"Self",$A$2:$A$7&$B$2:$B$7,0),))+(0.1*INDEX(C$2:C$7,MATCH($B12&"internal",$A$2:$A$7&$B$2:$B$7,0),))+(0.7*INDEX(C$2:C$7,MATCH($B12&"External",$A$2:$A$7&$B$2:$B$7,0),)),(0.7*INDEX(C$2:C$7,MATCH($B12&"Self",$A$2:$A$7&$B$2:$B$7,0),))+(0.3*INDEX(C$2:C$7,MATCH($B12&"internal",$A$2:$A$7&$B$2:$B$7,0),))) Ctrl+Shift+Enter
will do the trick
See the attached file:
  • Farina Book1.xlsx
If you want to make it easier to read use Named Formula
Emp_No: =Sheet1!$A$2:$A$7
Type: =Sheet1!$B$2:$B$7
C12: =IF(INDEX(C$2:C$7,MATCH($B12&"External",Emp_No&Type,0),),(0.2*INDEX(C$2:C$7,MATCH($B12&"Self",Emp_No&Type,0),))+(0.1*INDEX(C$2:C$7,MATCH($B12&"internal",Emp_No&Type,0),))+(0.7*INDEX(C$2:C$7,MATCH($B12&"External",Emp_No&Type,0),)),(0.7*INDEX(C$2:C$7,MATCH($B12&"Self",Emp_No&Type,0),))+(0.3*INDEX(C$2:C$7,MATCH($B12&"internal",Emp_No&Type,0),)))
See attached
  • Farina Book1.xlsx
I need to add few more conditions around. Please see the excel spreadsheet attached. Basically, I would like to add more conditions for each scenario and get the result like C32:K38 in the attached file. I have also put the rule against each one.
Thanks again!
  • Copy of Farina Book1.xlsx
Detailed Descriptions,
In the table below I would like to get a summary table by applying a formula based on the several conditions.They are
IF all the three (Self, Internal and External) are present then the Formula should be(20%Self+10%Internal+30%External)
IF only External and Internal are present then the formula should be (70%external+ 30% internal)
If only External and self are present then the formula should be (70% external+30% Internal)
If only Internal and self are present then the formula should be (30% Internal+70% self)
If only one type of Nomination (Self, Internal or External) if present then. Apply 100% of that.
  • Book1.xlsx
