    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Modify vba code
Discussion in 'VBA Macros' started by IKHAN, Feb 15, 2017.
  1. IKHAN
    IKHAN Member
    215
    Require assistance to modify code below
    As data is entered in column J6 : J19 cells , each cell in Column K to divide J6 :J19 by " J20"
    Example : J20 has data= 120
    user inputs in J6 as 10
    Column K6 result = J6/J20
    user inputs in J7 as 20
    Column K7 result = J7/J20
    and so on...
    Much Appreciated...
    Code (vb):
        ay = Target.Row
        ax = Target.Column
        If ax = 10 Then
            With Sheets("Output")
                Select Case ay
                    Case 5
                        x = WorksheetFunction.Match(Sheets("Output").Range("$J$5"), Sheets("Dropdown").Range("$G$1:$G$13"), 0) - 2
                        .Range(.Cells(6, 12 + x * 3), .Cells(20, 13 + x * 3)).Copy Destination:=.Range("$J$6")
                    Case 6 To 20
                      yy = WorksheetFunction.Sum(.Range("$J$6:$J$19"))
                        .Range("$K$4:$K$19").NumberFormat = "0%"
                        For y = 6 To 20
                          .Cells(y, 11) = .Cells(y, 10) / yy
                        Next y
                        .Cells(5, 12 + x * 3) = Sheets("Dropdown").Cells(2 + x, 5)
                        .Range("$J$6:$K$19").Copy Destination:=.Cells(6, 12 + x * 3)
                End Select
      Call Macro1
  2. vletm
    vletm Well-Known Member
    2,259
    hmm... @IKHAN
    Last time You wanted those values away and now back again!
    Do You know what do You want?
  3. Marc L
    Marc L Excel Ninja
    2,911
    Hi !
    Do not need a code but just formulas !
  4. IKHAN
    IKHAN Member
    215
    @ vletm ...Need values in col k , but calculations in col K is incorrect.
    Code worksheetfunction is suming up the range j6 :j9
    Require in col K to calculate based on adjacent col j cell and divide by col J20
    @Marc L .. I did try the formula before posting query, the code above overwrites the formula when data retrieved from other months dropdown list in J5
  5. vletm
    2,259
    Send that file here which has 'challenge'.
    and explain there
    before
    and
    after cases!
    What do that 'Macro' do?
  6. vletm
    2,259
    @IKHAN
    1) That 'Worksheet_Change' works ONLY-AND-ONLY with SAME LAYOUT which it has done. If You have changed LAYOUT then You have to modify Macro too.
    2) It NO NEED fixed formula to solve those %.
  7. IKHAN
    IKHAN Member
    215
    @vletm Test file is attached to the first post (Test drop.xlsx) and code above works for my layout for the attached file.
    Rattaching file..
    Only change reqd. in col K to calculate based on adjacent col J cell and divide by cell " J20"
    let me know..If you're unable to download test file.
  8. vletm
    2,259
    1) Why do You use .xlsx-files? then no Macros! No calculations!
    2) Is that Yellow [J21] or [J41] ALWAYS fixed (120)?
    3) Is that row 5 in correct format? Previous has more 'normal' looking.
  9. IKHAN
    IKHAN Member
    215
    @vletm
    For some reason - was unable to upload macro file, so have saved in .xlsx and posted code in thread.
    2) Is that Yellow [J20] or [J41] ALWAYS fixed (120)?
    - Yellow "J20" and 120 is not always fixed (User inputs that number monthly in J20) Thts the reason asking to ref. J21cell
    - J41 is sample field to show the output reqd. for this group
    Yes , Its correct format and works for above code.
  10. vletm
    2,259
    1) hmm...?
    2) You have used sum - not any more fixed as in Your samples
    I used my file - check again!
  11. IKHAN
    IKHAN Member
    215
    @vletm..
    Doesn't work.
    Still adding numbers in your sheet column J22
    Only change reqd. in col K to calculate based on adjacent col J cell by dividing cell " J20"
    If you're testin , Please use the attached test file and code.
    Code (vb):
        ay = Target.Row
        ax = Target.Column
        If ax = 10 Then
                Select Case ay
                    Case 5
                    Case 6 To 20
                        For y = 6 To 20
                        Next y
                        .Cells(5, 12 + x * 3) = Sheets("Dropdown").Cells(2 + x, 7)
                End Select
  12. vletm
    2,259
    @IKHAN - as I wrote in #6 reply:
    Your .xlsx has different layout!
    2) Find out why You cannot send .xlsb-files which worked.
    3) If You want/need to modify layout then You have to modify code too!
    It is not so called 'automatic'!
  13. IKHAN
    IKHAN Member
    215
    Thanks...
    I give up with this thread..Its not what am looking for.
    Please read my first post
  14. vletm
    2,259
    It was Your file!
    Delete from that file which You don't want to see!
    Add to that file what You want to see!
    Then I could see what is missing or what is too much!
  15. IKHAN
    IKHAN Member
    215
    @vetlm
    Have highlighted in red for incorrect output and highligted in green for reqd. results and commented for details.
    Require Formula j27/j$41 integrated in macro for col K range
    Note : ROW 26 TO 44 is for reference only- example of output reqd.
    Actual file to test starts from row 5 to row 20
  16. vletm
    2,259
    Okay ...
    I have tried to ask about that 'J20' few times...
    Now, You clearly wrote that 'User Inputs number to J20'!
    Was that only challenge; case 'J20'?
    >> Now, User have to InPut that number ... or message will come!
    >> If that 'J20' could be in 'J4' then this could use with more rows ...
    needs some changes to code..
    Thomas Kuriakose and IKHAN like this.
  17. IKHAN
    IKHAN Member
    215
    @vletm
    Excellentae... Thank you much....
  18. IKHAN
    IKHAN Member
    215
    @vletm
    If any row inserted , Breaks the code for J20
    Is there a way to always reference that cell to input hours
  19. vletm
    2,259
    @IKHAN
    Where do You insert row?
    If You insert row above original J20 then ...
    original code no work!
    Try ReRead #12 - red text!
    What about 'hours'?
    I cannot get idea without clear vision = file, good file!
  20. IKHAN
    IKHAN Member
    215
    Correct - Exisiting code will not work attached in test file .So needs to modified with your expertise.
    - If user adds a row between row 5 and 20, The "J20" cell must also move down (where user inputs number)
    See attached file
  21. vletm
    2,259
    This would be more easier for You.
    Those 'fixed' manually inputted blue values are above of 'Months'
    and
    You could add 'as many rows as needs' under 'Month' ...and so on...
  22. IKHAN
    IKHAN Member
    215
    @vletm
    Have other header files and data above row 5 in my original file, So can't have user input cell on top.
    Thanks for assisting again..
  23. vletm
    2,259
    ... would it better that "J20" would be in other 'workbook'?
    ... or 'K5'
    ... then 'users' could find it!
    Thomas Kuriakose likes this.
  24. IKHAN
    IKHAN Member
    215
    @vletm
    Sorry No...Have that format for a specific reason...putting together a project with puzzles..
    That's the reason require user input in J20 and as user's also if needed will be adding rows or deleting rows between row5 to to row 20.
    If rows added/deleted - J20 cell must always be referenced in your code in post #16 (Good file)
  25. vletm
    2,259
    No ...
    If You cannot tell enough details BEFORE
    then I won't just going to make more guesses!
    Or
    Would it be same way easier for You that
    You would tell BEFORE what I won't do next time?
    >> maybe that 'J20'-cell would be in other workbook alone?
Share This Page
