Multi item add
delta
i upload file in sheet "Bill" create a button when click on button the data will be add on sheet "Data" but my problem is consignee name, Invoice number, Invoice date will be add four time, i want to consignee name, Invoice number, Invoice date will be add only one time
this macro will be in module.
▬▬▬▬▬▬▬▬▬ Mod edit : thread moved to appropriate forum !
  • PSC_2017.xlsm
Sub ADD_DATA()
  Dim rng As Range
  Dim temp As Variant
  Dim i As Long
  Dim a As Long
  Dim rng_dest As Range, flg As Boolean  '★
  i = 1
  Set rng_dest = Sheets("Data").Range("D:I")
  ' Find first empty row in columns D:G on sheet Invoice data
  Do Until WorksheetFunction.CountA(rng_dest.Rows(i)) = 0
    i = i + 1
  Loop
  'Copy range B19:G28 on sheet Bill to Variant array
  Set rng = Sheets("Bill").Range("B19:G28")
  ' Copy rows containing values to sheet Data
  For a = 1 To rng.Rows.Count
    If WorksheetFunction.CountA(rng.Rows(a)) <> 0 Then
      If Not flg Then  '★
        'Copy Company name
         Sheets("Data").Range("A" & i).Value = Sheets("Bill").Range("C3").Value
         flg = True
      End If  '★
      rng_dest.Rows(i).Value = rng.Rows(a).Value
      'Copy Invoice number
      Sheets("Data").Range("B" & i).Value = Sheets("Bill").Range("F5").Value
      'Copy Date
      Sheets("Data").Range("C" & i).Value = Sheets("Bill").Range("F7").Value
      ' DESPATCHED THROUGH
      Sheets("Data").Range("V" & i).Value = Sheets("Bill").Range("F9").Value
      ' DESPATCHED FROM
      Sheets("Data").Range("W" & i).Value = Sheets("Bill").Range("F11").Value
      ' TRANSPORT
      Sheets("Data").Range("T" & i).Value = Sheets("Bill").Range("F13").Value
      ' VAT NO
      Sheets("Data").Range("Y" & i).Value = Sheets("Bill").Range("B7").Value
      ' CST NO
      Sheets("Data").Range("Z" & i).Value = Sheets("Bill").Range("B9").Value
      ' P.O. NO.
      Sheets("Data").Range("P" & i).Value = Sheets("Bill").Range("C16").Value
      ' S.B. NO.
      Sheets("Data").Range("O" & i).Value = Sheets("Bill").Range("D16").Value
      '  FROM
      Sheets("Data").Range("AD" & i).Value = Sheets("Bill").Range("E16").Value
      ' LR NO.
      Sheets("Data").Range("S" & i).Value = Sheets("Bill").Range("F16").Value
      ' MAKE
      Sheets("Data").Range("Q" & i).Value = Sheets("Bill").Range("G16").Value
      ' ADDRESS
      Sheets("Data").Range("X" & i).Value = Sheets("Bill").Range("B4").Value
      ' Vat 4%
      Sheets("Data").Range("J" & i).Value = Sheets("Bill").Range("G30").Value
      ' Add. Vat 1%
      Sheets("Data").Range("K" & i).Value = Sheets("Bill").Range("G31").Value
      ' Freight
      Sheets("Data").Range("AA" & i).Value = Sheets("Bill").Range("G32").Value
      i = i + 1
  Next a
Sub ADD_DATA()
  Dim rng As Range
  Dim temp As Variant
  Dim i As Long
  Dim a As Long
  i = 1
    i = i + 1
  Loop
      If Not flg Then  '★
        'Copy Company name
         flg = True
      End If  '★
      'Copy Date
      ' DESPATCHED FROM
      ' TRANSPORT
      ' VAT NO
      ' CST NO
      ' P.O. NO.
      ' S.B. NO.
      '  FROM
      ' LR NO.
      ' MAKE
      ' ADDRESS
      ' Vat 4%
      ' Add. Vat 1%
      ' Freight
      i = i + 1
  Next a
perfect answer Briant
Thanks a lot
Sub ADD_DATA()
  Dim rng As Range
  Dim temp As Variant
  Dim i As Long
  Dim a As Long
  i = 1
    i = i + 1
  Loop
      If Not flg Then    '★
       'Copy Company name
          'Copy Date
         flg = True
      End If    '★
      ' DESPATCHED FROM
      ' TRANSPORT
      ' VAT NO
      ' CST NO
      ' P.O. NO.
      ' S.B. NO.
      '  FROM
      ' LR NO.
      ' MAKE
      ' ADDRESS
      ' Vat 4%
      ' Add. Vat 1%
      ' Freight
      i = i + 1
  Next a
