Graham Cobden
Hi All,
I am trying to discover how to do a lookup to a cell with 2 criteria....easy I hear you say....well.....
I have a set of data over 5 columns of which the 2 criteria are in columns A and B. In column A are the names of companies which sometimes appear each day and sometimes do not. In column B in the date that links to the company name. In column E is the contact rate % which I want to 'look up'. Essentially I am trying to create a formula which I can drag into the table on the right which essentially says that if the date = 01/04/2015 and the company = leads wizard, pull the contact % (which is 100%). I want this formula to then be able to drag down so it looks up a different company name but still for the first. I have achieved this but the issue comes when I want to drag the formula across to the right into the 02/04/2015 column. The formula returns #NA and errors no matter what method I try be it index match or multiple lookup or using ctrl alt and enter.
Any help would be greately appreciated!!
