Hello Can anybody please help me on this.
1. When User Enter the Employee ID in HOME Page, it should fetch the name from "Sheet 2".
2. When LOGIN Button is pressed - it should display the Time (Once Login is pressed - Log In Button should be disabled)
3. When LOGOUT Button is pressed - it should display the Time (Once LogOut is pressed - Log Out Button should be disabled)
4. YOUR TOTAL LOGIN HRS FOR TOTDAY IS - when LOGOUT is pressed, it should display total hours spend today.
(NOTE: Other than Employee ID Text Box, all other Items should be disabled for editing for user)
5.Once Log In is pressed - Current Date, Employee Name, Login Time sould be saved in Database sheet. (Should not be editable)
6.Once Log Out is pressed - it should display the time in Logout Column.(Should not be editable)
I had attached the excel file which needs these changes. Kindly update the coding to the attachment, which will be helpful.
