SONJOE JOSEPH
Dear all Excel Experts,
Good Morning. I am attaching a file were u will find the Date, CP ( Closing Price ), DR (Daily Return) and Yearly Daily Average Return (YDAR). The question is on a constant cell ie "N2" i want the values starting from D253. You will find here that on 1st Jan,13 the YDAR was 0.10% so this should appear in the constant "N2" cell. On the next day ie 2nd Jan,13 the YDAR was also 0.10% so the constant "N2" cell has to change to 0.10%. So this process has to continue. (This is one way of doing)
Second Method
Let suppose that in Range "D" the values of YDAR from D253 to D268 are not there. Whether we can make a formula were i need to find the YDAR in cell "N2" on a yearly basis ie 365 days. For eg from 1-Jan,13 to 3rd Jan,12 the YDAR is 0.10% . So the the cell "N2" has to update the value 0.10%. On the next day ie 2nd Jan,13 to 4-Jan,12 the YDAR is same 0.10% so the cell "N2" has to again change to 0.10%. So this process has to continue.
Some times the YDAR values changes so each result has to updated in the "N2" cell ie the key thing here.
Please help me to solve this problem and i'm attaching a working file for your reference.
Thanking You,
With Regards,
Sonjoe Joseph.
Second Method
Thanking You,
With Regards,
Sonjoe Joseph.
