Need help with loop entry
salviakshay
Hi All,
I am trying to create a radom sampler for selecting random cases for audit, attached si the macro created.
Within this macro i am unable to add the loop entry to ensure that the random formula is applied to the last entry in the 1st column.
Kindly assist
  • Random Sampler.xlsm
I think this is what you want, in that the problem was figuring out where the last row of data was. There was a lot of sorting going on in your macro with no comments, but I'm guessing the idea is to apply a random number in col O, sort on that value, and then filter.
Sub Sample()
Dim lastRow As Long
'Where is the last row of data?
With ActiveSheet
    .AutoFilterMode = False
    lastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
'Apply the formula
With Range("O2:O" & lastRow)
    .Formula = "=RAND()"
    .Copy
    .PasteSpecial xlPasteValues
'Add sort fields
With ActiveWorkbook.Worksheets("Sheet1").Sort.SortFields
    .Clear
    .Add Key:=Range("O2:O" & lastRow), SortOn:=xlSortOnValues, Order:=xlDescending, DataOption:=xlSortNormal
'Apply sort
    .SetRange Range("A1:O" & lastRow)
    .Header = xlYes
    .MatchCase = False
    .Orientation = xlTopToBottom
    .SortMethod = xlPinYin
    .Apply
'Re-filter data
ActiveSheet.Range("$A$1:$O$" & lastRow).AutoFilter Field:=10, Criteria1:="=Closed" _
    , Operator:=xlOr, Criteria2:="=Reserved"
Thanks Luke, this works perfect....I have made certain ammendments to suit the sort prefrences.
One other thing in addition to the above macro, is there a entry to select the data matching two criteria and pasting it to a diffrent sheet.
For eg in the attached sheet post running macro 1, macro 2 should do following:-
Column H is going to be the agent list, it should select the first entry for every unique combination of column b and column K (combined) and paste it to a new sheet.
I have ammended the sample sheet, the macro should copy result of row 2, (ignore row 3 as details in column b and k match earlier entry), copy result of row 4 and 6 ( as the combination of b and k is diffrent ) do so for other agents and paste it to a new sheet.
Each agent getting their own sheet, or each unique combination getting its own sheet?
Here ya go, two different macros.
  • Random Sampler 2 Macros.xlsm
Hi Luke,
How do i edit the last row entry to copy the data from range A2 to last data of column E and paste it to a new sheet. currently the code reads data in the sheet only for column A
If you want it to go till last row in col E, we can set the variable via
lastRow = .Cells(.Rows.Count, "E").End(xlUp).Row
Is that what you mean?
Ah, that would be in the CopyAgents macro then, not the first one. New macro, with one line changed (marked with comment)
Sub CopyAgents()
Dim strName As String
Dim strCombo As String
Dim ws As Worksheet
Dim rngAgents As Range
Dim c As Range
'Initialize values
strCombo = ""
strName = ""
With ActiveSheet
    Set rngAgents = Intersect(.AutoFilter.Range.Offset(1), Range("H:H")).SpecialCells(xlCellTypeVisible)
    If rngAgents Is Nothing Then
        MsgBox "No visible rows"
        Exit Sub
    Set ws = ThisWorkbook.Worksheets.Add(after:=ThisWorkbook.Worksheets(ThisWorkbook.Worksheets.Count))
    ws.Name = "Detail Info"
    For Each c In rngAgents
        If c.Value <> "" Then
            If c.Value <> strName Then
                'New Agent
                strName = c.Value
                strCombo = ""
            If c.Offset(, -6).Value & c.Offset(, 3).Value <> strCombo Then
                'New Combination
                'THIS IS THE LINE THAT CHANGED
                Range(Cells(c.Row, "A"), Cells(c.Row, "E")).Copy ws.Cells(.Rows.Count, "A").End(xlUp).Offset(1)
                strCombo = c.Offset(, -6).Value & c.Offset(, 3).Value
    Next c
Hi Luke sorry if i sound stupid but i am trying to add the modifed code to following code, after the pivot refresh the next code should copy the data from a2 to end of E and paste it to a new workbook
Sub Random_Sampler_v2()
' Random_Sampler_v2 Macro
With ActiveSheet
'Apply the formula
With Range("m2:m" & lastRow)
.Formula = "=RANDBETWEEN(0,99999999999)"
Sheets("Pivot").Select
ActiveSheet.PivotTables("PivotTable3").PivotCache.Refresh
Here's where I'd start to learn more about VB:
http://chandoo.org/forum/threads/vba-tutorial-3-parts-pdf.14544/
http://chandoo.org/wp/excel-vba/videos/
Good compilation of free videos/tutorials
As for the code question, rather than merge the two, you can leave the Copy macro separate, and call it from the 1st macro like so:
With ActiveSheet
'Apply the formula
'Call our other macro
Call CopyAgents
Sub CopyAgents()
Dim ws As Worksheet
Dim wb As Workbook
Dim c As Range
'Initialize values
strCombo = ""
strName = ""
With ActiveSheet
        Exit Sub
    Set wb = Application.Workbooks.Add
    Set ws = wb.Worksheets(1)
                'New Agent
                strName = c.Value
                strCombo = ""
                'New Combination
                .Range(.Cells(c.Row, "A"), .Cells(c.Row, "E")).Copy ws.Cells(.Rows.Count, "A").End(xlUp).Offset(1)
    Next c
Hi Luke,
I have attached the sample file, above code was giving me error while calling the second code.
In the attached file, the second macro should copy the details from "pivot" sheet starting from a2 till E last row and paste it to a new workbook
  • Randomizer.xls
With a PivotTable, you've compeltely changed the layout of the data, and we now have spaces introduced. Where are the agents? Which columns are we checking if they match? Or, if we're no longer doing that, and it's literally a straight copy, then macro is shortened to:
Dim lastRow As Long
Dim ws As Worksheet
Dim wb As Workbook
With ThisWorkbook.Worksheets("Input")
    'Apply the formula
    .Range("m2:m" & lastRow).Formula = "=RANDBETWEEN(0,99999999999)"
ThisWorkbook.Worksheets("Pivot").PivotTables(1).PivotCache.Refresh
'Don't care about logic, just copy info
With ThisWorkbook.Worksheets("Pivot")
    Intersect(.Range("A2", .Cells(.Rows.Count, "E").End(xlUp)), .UsedRange).Offset(1).Copy ws.Range("A1")
HI Luke, sorry i forgot to mention that the copy agent logic was excluded. it was a bit confusing when the randomizer was used. i found a better way of doing it through PIVOT in chandoo tutorial http://chandoo.org/wp/2014/01/31/how-to-select-a-random-sample-from-all-your-data/.
The above macro works great now and suits the requirement. thank you for your prompt assistance in the query.
PS:- the article provided by you on tutorials is great
Hi luke,
In addition to the attached earlier code, i am trying to have the automated email functionality, i found a code from some post (by you :)) and used the following to achive this. however in the earlier macro the new workbook is being created with a new name how do i edit the macro to send the new workbook as an attachment. (I have xxx the email address purposly)
Sub Mail_workbook_Outlook_1()
'Working in Excel 2000-2013
  Dim OutApp As Object
  Dim OutMail As Object
  With OutMail
  .to = "[EMAIL]xxx@xxx.com[/EMAIL]"
  .CC = "[EMAIL]xxx@xxx.com[/EMAIL]"
  .BCC = ""
  .Subject = "Evaluations for Today"
  .Body = "Hi Team"
  .Attachments.Add ActiveWorkbook.FullName
  'You can add other files also like this
  '.Attachments.Add ("C:\test.txt")
  .Send  'or use .Display
  On Error GoTo 0
  Set OutMail = Nothing
  Set OutApp = Nothing
Not quite sure what the status/layout of the other macros currently, but here's a structure you could mimic to email a newly created workbook.
Sub ExampleCode()
'This is just to show how to call the 2nd macro
Dim ws As Workbook
'So, we've create a new workbook, how to email it? Know that we need to save the file
'so you'll need to come up with some sort of naming system already
Set wb = Workbooks.Add
wb.SaveAs "C:\Test.xlsx"
'We then call the emailing macro, passing it the full file name
'so it can attach it
Call Mail_workbook_Outlook_1(wb.FullName)
Sub Mail_workbook_Outlook_1(fileName As String)
'Argument added, so we must now pass along the file name
  With OutMail
  .BCC = ""
  .Body = "Hi Team"
  .Attachments.Add fileName
  On Error GoTo 0
Hi Luke,
So what i am trying to do is post running following code
Sub Random_Sampler_Final()
Dim lastRow As Long
Dim ws As Worksheet
Dim wb As Workbook
  'Apply the formula
The new workbook should be email to specific email address, currently the listed code is emailing the workbook from which the pivot is copy pasted and not the new workbook[/CODE]
How's this? I proposed naming the extracted file with a date stamp, but change it if needed.
Dim lastRow As Long
Dim ws As Worksheet
Dim wb As Workbook
  'Apply the formula
Dim fName As String
'CHANGE THIS NEXT PART
'What to name attachment
fName = ThisWorkbook.Path & "\Extract_" & Format(Date, "yyyymmdd") & ".xlsx"
wb.SaveAs fName
  With OutMail
  .to = "xxx@xxx.com"
  .CC = "xxx@xxx.com"
  .BCC = ""
  .Body = "Hi Team"
  On Error GoTo 0
HI Luke,
This works great i have edited the macro to include current time as well with Format(Now, "dd-mmm-yy h-mm-ss") command.
Will it be possible to save the new created file to a diffrent folder, currently it saves the file in the folder from where the randomizer is being run. what if i need to change the path. how do i edit the fName = ThisWorkbook.Path string
