    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Need macro for Attendance Tracker
Discussion in 'VBA Macros' started by pi_sa11, Jun 19, 2017 at 8:18 AM.
  1. pi_sa11
    pi_sa11 New Member
    7
    I wanted to develop a excel macro which should perform below operations. I have attached file for the reference. In sheet "Detail" raw data is placed. In row 7 from data & to date is present which will be a month.
    1) Now develop a macro which will insert automatic date in a month in row 1 of the sheet "InTime", "InitialStatus", "ModStatus".
    2) Develop a macro which will insert in time, out time & work time in accordance with date, employee name & employee ID in sheet InTime. Please note the structure of the sheet InTime is demo only, as out time & work time columns are not present. you may insert asper your convenience.
    3) Write a macro which will insert automatic data of attendance i.e.. P(Present),A(absent) in sheet "InitialStatus" with respect to date, employee name & employee id.
  2. p45cal
    p45cal Well-Known Member
    694
    Code (vb):
    Sub Status()
    Set WorkSht = Sheets("Detail")
    Set NewSht = Sheets.Add(after:=Sheets(Sheets.Count))
    Set Destn = NewSht.Range("A3")
    With NewSht
      .Range("C1").Value = 1
      .Range("C1").DataSeries Rowcol:=xlRows, Type:=xlLinear, Stop:=31
      .Range("A2:B2").Value = Array("EmployeeName", "EmployeeID")
      .Range("C2:AG2").Value = "Status"
    With WorkSht.Columns(1)
      Set c = .Find("Empcode :", lookat:=xlWhole, LookIn:=xlFormulas, searchformat:=False)
      If Not c Is Nothing Then
        firstAddress = c.Address
        Do
          Set myDataRng = c.Range("B1,D1,B12:AF12")
          Destn.Value = myDataRng.Areas(2).Value  'name
         Destn.Offset(, 1).Value = myDataRng.Areas(1).Value  'empcode
         Destn.Offset(, 2).Resize(, 31).Value = myDataRng.Areas(3).Value
          Set Destn = Destn.Offset(1)
          Set c = .FindNext(c)
        Loop While Not c Is Nothing And c.Address <> firstAddress
    Sub InTime()
    With NewSht
      .Range("C2:AG2").Value = "InTime"
        Do
          Set myDataRng = c.Range("B1,D1,B5:AF5")
         With Destn.Offset(, 2).Resize(, 31)
            .NumberFormat = "hh:mm"
    Thomas Kuriakose likes this.
Share This Page
