To add to what Luke has already posted , I would like to point out that when you use the MAX function , the IF function may not always be necessary. In your case , even the following formula will give the correct result :
=MAX(($A$3:$A$7=$G$1)*($B$3:$B$7=$G$1)*($C$3:$C$7))
This is because the first and second terms return an array of 0s and 1s ; 0 where the condition is not satisfied , and 1 where the condition is true. Thus , the resulting array will contain the values from the range $C$3:$C$7 where both conditions were met , and 0 elsewhere. The MAX function will therefore return the correct result.
It is a different matter when you wish to retrieve the minimum value.
In this case , where the conditions are not satisfied , the multiplication of the 3 arrays will return 0 , and this may not be the minimum value. To ensure that the correct minimum value is returned , the IF becomes necessary , so that where the conditions are not satisfied , the IF function puts in a FALSE value , which is ignored by the MIN function , as in :
=MIN(IF(($A$3:$A$7=$G$1)*($B$3:$B$7=$G$1),($C$3:$C$7)))
In both cases , the formulae are array formulae , to be entered using CTRL SHIFT ENTER.
