Monty
Hello Everyone!
This is little tricky at the same time found interesting to reconcile two sheets and put the data in "Recon" Tab.
There are 3 Tabs:
Tab1 : MCR
Tab2 : IR
Tab3 : Recon
Step 1: Filter (MCR Tab) in C column with ESG_FLOW_USD and "G" column with 1USD AND 2USD.
Pick up first visible cell of "E" column that is "Fo_Trade_ID" and check in the "IR" tab if that exists if exists sum up "E" column and take the amount...no need to match the amount and put the same in "Recon" sheet the entry and also need to fill by the macro staus as matching and not matching.
I have give clear notes in attached file...tried to explain as easy as possible.
Really appreciate your help.
There are 3 Tabs:
Tab1 : MCR
Tab2 : IR
Tab3 : Recon
