Hi to all,
I have a Client Data base which has been saved in Excel Sheet. Each Client has it own Excel File. Now, What i Want is to Pull Data from Each Client in a Prefixed Form Format. Now i'm in Doubt that Formulas will work. Hence, I Need VBA Code to pull Data from Client Database. I have added 2 Sheets namely 'Working sheet' and 'Queries' in the Sample Workbook. What i want is A VBA Code Which will pull Data from Queries Sheet to Working sheet which contains a form which is a fixed pattern. Few Cells Highlighted with blue colors Contains Formulas hence it should be left untouched. Some of the Fields in Queries sheet have multiple Rows which also needs to pe pulled in Working Sheet. Any Help is Greatly Appreciated. Thanks in Advance
