not able to calculate formula to all rows
Hi Pcosta,
Thanks for you help and suggestions but i am not able to make it Dynamic getting many errors ..so what i have done is i replicated the data at home and created MACRO and made changes what i know and attached all documents so that you can check and help me in making it Dynamic.
i have attached instruction document how this macro has been created and all the steps for preparing the report
please help in this as its very Big Report and very important as it consumes lot of time to prepare it.
let me know if you need more info.
Thanks in advance.
  • MACROCRM_TESTING.xlsm
  • RAW_DATA.xlsx
  • Template_backup.xlsx
  • Instructions.docx
Try the attached file... run the "Report" subroutine and wait for the "Report complete!" message.
Note: You don't need to open the RAW_DATA file first. The macro will prompt you to select it from a dialog box. Just open the "Template" and run the code... if I didn't mess up it should work as intended.
Hope this helps
  • Template_backup.xlsm
Hi Pcosta,
Excellent !!!!! its working perfectly and will test this for 2 more days with different data.. it took time to reply you because i am trying to understand how you wrote the code... i didnt expected the reply from you today but i am very happy that you have replied with solution .. i am very thankful to you....
only one question to you....as we are copying multiple data in sheets i don't think they overlap .. i saw there is 2 rows gap in between data ....
Hi Pcosta,
You are welcome :)... test it out thoroughly and let me know for any concerns.
About your question... it won't overlap. When copying from Production calls and Non-Production calls, for instance, to the same destination, it will leave a 2 row gap between both sets of data, similar to the example provided. That gap isn't fixed, i.e., I didn't specify where it should start pasting the second set of data... it will dynamically look for the previous data and paste 3 rows below it.
Hi Pcosta,
i checked the report and its working perfectly.
Thanks a Ton for sparing your time and preparing it.
i don't know to what extent i can take your help but i have few more reports like this which i am trying to prepare using macros. they have some quarterly and half yearly calls calculations for which dates keep changing every quarter.
Thanks once again for your valuable time .
your :awesome:.
Hi Pcosta,
i need small change the report.
lrow = Sheets(3).UsedRange.Rows.Count
    For Each c In Sheets(3).Range("M2:M" & lrow)
        If c > 0 And c <= 24 And IsInArray(c.Offset(, -2), brr) = True Then
            c.EntireRow.Copy Sheets(11).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    Sheets(1).Rows(1).Copy Sheets(11).Cells(Rows.Count, 1).End(xlUp).Offset(3)
    lrow = Sheets(4).UsedRange.Rows.Count
    For Each c In Sheets(4).Range("M2:M" & lrow)
and below we have calculated at column(M)= N2 - O2
but for sheet 11 the formula should be (M) = O2-N2 how to do this.
Dst.Activate
    lrow = Sheets(1).UsedRange.Rows.Count
    Sheets(1).Range("Q:T,W:AD").Delete
    Sheets(1).Columns("M:M").Insert Shift:=xlToRight
    Sheets(1).Range("M2").Formula = "=N2-O2"
    Sheets(1).Range("M2:M" & lrow).FillDown
    Sheets(1).Range("M1").Value = "SLA HRS LEFT"
If by sheet 11 you mean the "7.Breached Today" sheet, replace code with:
Sub Report()
    Dim Src, Dst As Workbook
    Dim c As Range
    Dim lrow, i As Integer
    Dim SrcName, arr(9), brr(10) As String
    Set Dst = ActiveWorkbook
    SrcName = GetFile("C:\")
    If SrcName = "" Then
        MsgBox "Canceled by user request!", vbInformation
        Exit Sub
    Workbooks.Open SrcName
    Set Src = ActiveWorkbook
    arr(0) = "WIP"
    arr(1) = "With Assignee"
    arr(2) = "With CCB Approver"
    arr(3) = "With CCB Approver After Patch Initiation"
    arr(4) = "With Reviewer For Clarification"
    arr(5) = "Initiation"
    arr(6) = "With Support Team for Ownership"
    arr(7) = "With Release Manager Team For RCD Approval"
    arr(8) = "With Reviewer For Patch"
    arr(9) = "With Reviewer For Closure"
    brr(0) = "WIP"
    brr(1) = "With Assignee"
    brr(2) = "With Requestor For Clarification"
    brr(3) = "With CCB Approver"
    brr(4) = "With CCB Approver After Patch Initiation"
    brr(5) = "With Reviewer For Clarification"
    brr(6) = "Initiation"
    brr(7) = "With Support Team for Ownership"
    brr(8) = "With Release Manager Team For RCD Approval"
    brr(9) = "With Reviewer For Patch"
    brr(10) = "With Reviewer For Closure"
    Src.Sheets(1).UsedRange.Copy Dst.Sheets(1).Cells(1, 1)
    Src.Close False
    Dst.Activate
    For i = 2 To Sheets.Count
        With Sheets(1).Rows(1)
            .Copy Sheets(i).Rows(1)
    For Each c In Sheets(1).Range("E2:E" & lrow)
        If InStr(c, "FINCRM 10.3.") = 0 And InStr(c.Offset(, -3), "ITL") = 0 And InStr(c.Offset(, -3), "URALSIB") = 0 And InStr(c.Offset(, 14), "CUSTOMIZATION_ISSUE") = 0 And InStr(c.Offset(, 14), "SIT_CUSTOMISATION") = 0 And InStr(c.Offset(, 14), "CUSTOMISATION REQUEST") = 0 Then
            c.EntireRow.Copy Sheets(2).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    lrow = Sheets(2).UsedRange.Rows.Count
    For Each c In Sheets(2).Range("R2:R" & lrow)
        If c = "PRODUCTION" Then
            c.EntireRow.Copy Sheets(3).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
        If c <> "PRODUCTION" Then
            c.EntireRow.Copy Sheets(4).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
        If c > 0 And c <= 120 And IsInArray(c.Offset(, -2), arr) = True Then
            c.EntireRow.Copy Sheets(5).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    Sheets(1).Rows(1).Copy Sheets(5).Cells(Rows.Count, 1).End(xlUp).Offset(3)
        If c > 0 And c <= 120 And c.Offset(, -2) = "With Requestor For Clarification" Then
    Next c
            c.EntireRow.Copy Sheets(6).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    Sheets(1).Rows(1).Copy Sheets(6).Cells(Rows.Count, 1).End(xlUp).Offset(3)
    Next c
        If c > 0 And c <= 48 And IsInArray(c.Offset(, -2), arr) = True Then
            c.EntireRow.Copy Sheets(7).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    Sheets(1).Rows(1).Copy Sheets(7).Cells(Rows.Count, 1).End(xlUp).Offset(3)
        If c > 0 And c <= 48 And c.Offset(, -2) = "With Requestor For Clarification" Then
    Next c
            c.EntireRow.Copy Sheets(8).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    Sheets(1).Rows(1).Copy Sheets(8).Cells(Rows.Count, 1).End(xlUp).Offset(3)
    Next c
    For Each c In Sheets(3).Range("K2:K" & lrow)
        If c = "With CCB Approver" Then
            c.EntireRow.Copy Sheets(9).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    For Each c In Sheets(4).Range("K2:K" & lrow)
            c.EntireRow.Copy Sheets(10).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    Next c
    Next c
    For Each c In Sheets(3).Range("Q2:Q" & lrow)
        If c = "Not Met" Then
            c.EntireRow.Copy Sheets(12).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    For Each c In Sheets(4).Range("Q2:Q" & lrow)
            c.EntireRow.Copy Sheets(13).Cells(Rows.Count, 1).End(xlUp).Offset(1)
    Next c
    For Each c In Sheets(11).Columns("M:M").SpecialCells(xlCellTypeFormulas)
        c.Formula = "=O2-N2"
    Next c
    MsgBox "Report complete!", vbInformation
Private Function IsInArray(valToBeFound As Variant, arr As Variant) As Boolean
Dim element As Variant
On Error GoTo IsInArrayError: 'array is empty
    For Each element In arr
        If element = valToBeFound Then
            IsInArray = True
            Exit Function
    Next element
Exit Function
IsInArrayError:
On Error GoTo 0
IsInArray = False
End Function
Function GetFile(strPath As String) As String
    Dim File As FileDialog
    Dim sItem As String
    Set File = Application.FileDialog(msoFileDialogFilePicker)
    With File
        .Title = "Select RAW DATA file"
        .AllowMultiSelect = False
        .Filters.Clear
        .Filters.Add "Excel files only", "*.xls; *.xlsx, *.xlsm"
        .InitialFileName = strPath
        If .Show <> -1 Then GoTo NextCode
        sItem = .SelectedItems(1)
NextCode:
    GetFile = sItem
    Set File = Nothing
End Function
What I did was go through each cell with formula in column M of sheet 11, replacing the formula with "=O2-N2".
Just so you can understand better, below you can find the specific lines I added in the code above:
    Next c
Thanks for the Reply ....Yes i saw the code changes you have done...but previously we have appluied the formula in sheet one and copied data to sheet 3 and once again applied the conditions in sheet3 and copied to sheet11 ..but now we are directly appying formula in sheet11 ...one clarification needed does it check the condition
If c > 0 And c <= 24 And IsInArray(c.Offset(, -2), brr) = TrueThen
       EndIf
and how it will copy the same data in sheet11
just one info .....for example N2= 14 and O2=13, ( M=N2-O2) M= 1 if we do reverse it will be -1 , can we do all plus values to minus (- ) and all minus values to (+)...if i am not wrong...
Hi Pcosta,
I have searched in the net and found something called (c.Value = -c.Value) and done below changes ....let me know what i have done is right or wrong.
    c.Value = -c.Value
            c.EntireRow.Copy Sheets(11).Cells(Rows.Count,1).End(xlUp).Offset(1)
        c.Value = -c.Value
    Next c
    Sheets(1).Rows(1).Copy Sheets(11).Cells(Rows.Count,1).End(xlUp).Offset(3)
    c.Value = -c.Value
        c.Value = -c.Value
    Next c
       EndIf
I see what you mean... My apologies, I totally forgot about that.
Also, this last code I posted is incorrect as I didn't copy the formula down to the other cells, meaning that sheet 11 (column M) would get O2-N2 in all rows and not O2-N2, O3-N3 and so on.
Code revised below:
Sub Report()
    Dim c As Range
        Exit Sub
    arr(0) = "WIP"
    brr(0) = "WIP"
    Src.Close False
    Dst.Activate
    Next c
    Next c
    Next c
    Next c
    Next c
    Next c
    Next c
    Next c
    Next c
    Next c
    Next c
    Next c
    Next c
        If -c > 0 And -c <= 24 And IsInArray(c.Offset(, -2), brr) = True Then
    Next c
    Next c
    Next c
    Next c
        c.FormulaR1C1 = "=rc[2]-rc[1]"
    Next c
            IsInArray = True
            Exit Function
    Next element
Exit Function
IsInArrayError:
On Error GoTo 0
IsInArray = False
End Function
    Dim sItem As String
    With File
        .Filters.Clear
NextCode:
    GetFile = sItem
    Set File = Nothing
End Function
It should be OK now, sorry again :(
That is correct, c.value=-c.value is the same as O-N. However, the way you implemented it is not. You see, when you use the value method here, it will replace the formula and convert the cells content to value (similar to "Paste Values").
Since this is the last copy/paste operation involving the column M of sheet 3 and 4, it would probably work the same way, but if there were more operations using those values you would need to change them back to the original values.
So, what I did instead was use "-c>0 and -c<=24" which is the same as saying "O-N>0 and O-N<=24".
Then I changed the formula in the destination (sheet 11), just so it matches the criteria used.
It seems to be working correct.......Thanks a lot Pcosta.... if possible can you please look into my other post....i have another same kind of report with Summary report in that i have 8 sheets from that i am trying to make one Pivot table or i will combine all pivot table in summary sheet.:)
Don't mention it ;)
About the other thread, I will take a look at it and if I have any suggestion I will post there.
