Plot chart with unique values
webmax
Hi
Kindly find the attached excel i have a different levels and values.
The Level is
5L
4H
6M
While putting the chart it is showing 5L four Times, 4H two times ,6M two timesTimes that need to come in a single in X Axis with plotting the values.
Need the guidance.
Shahul
  • chart question.xlsx
so, a chart that looks like this?
The attached file has 2 series. 2nd series is actually a line plotted along y=0, with data labels. The data labels are displaying the 5L, 4H, and 6M. The real x-axis is not showing any labels.
  • chart question LM.xlsx
Hi
I want chart like plotted dots.
Can you explain how you have taken the X axis in the single column.
first, I created the lookup table to convert your labels into a value of 1,2 or 3. Then, created formulas in col G to say what the X-value should be.
Right-click on chart, select data, modified the current series to use the new calculated values for the X-values, rather than the labels.
Then, still in the Select Data dialogue, added a new series. X-values are the numbers in Col K of the lookup table we build. Y-values can be anywhere where cell values are 0.
Format original x-axis to have no labels, major unit is 1. Format new series to show data labels below. format the series to have no line, no marker. With the data labels, select each one individually and link to correct cell
  • chart question LM2.xlsx
Hi
I tried to put the chart but it is not working kindly help
Hi
Thanks for your efforts but i still stuck with the steps can u provide step step in screen shot.
Shahu
