I'm facing with an annoying issue with power query sorting action.
Seems Power query sorting manage differently the special chars than Exel in the sort.
LEt me explain with a basic example :
I have a table with the basic following values, unsorted
Col1
val1
¨val1
_val1
If in Excel I sort ascending the table by Col1, result is :
Col1
_val1
¨val1
val1
and it is the result I expect.
If these data are now in power query, I execute the sort in power query with Table.Sort instruction and load data to workbook
the result is now :
Col1
_val1
val1
¨val1
You can find attached the workbook
So the Excel sorting is different from the Powerquery sorting, which cause some issues for me
Any idea on how I can use power query and having the excel sorting behavior ?
The single workaround found is to create a macro that refresh power query table, and after sort the result in excel
Thank you for your help.
Col1
val1
¨val1
_val1
Col1
_val1
¨val1
val1
the result is now :
Col1
_val1
val1
¨val1
