PowerPivot Calculating Max of column
txfrazier
I'm trying to calculate the maximum number in one column (Col 3) based on the common values in another column (Col 1). Example given. Thanks for your help.
  • Max of Column 3 example.xlsx
Do you need it as measure or calculated column?
I don't have PowerPivot at work.
But, typically you'd use FILTER as criteria in calculation.
= CALCULATE(MAX(Tabel1[Col3]), FILTER(Table1, Table1[Col1] = "xxxx"))
Thanks. I'm trying to create a calculated column. I tried your suggestion but it only returned BLANK. Should I use something besides "xxxx" at the end of the formula? I removed the "xxxx" and it returned the largest number in the whole table for col 3.
Yes, replace with your condition.
Something like...
=CALCULATE(MAX(Table1[Col3]),FILTER(Table1,Table1[Col1]=EARLIER(Table1[Col1])))
