Problem Sort Data by Sum of Total Amount
Paijo
Hi experts
I have problem with sort or ranking by SUM of total amount by Names, Im already done with helper column and LARGE function, but is that possible with single formula? I see this forum is the great forum I've ever follow, thanks in advance...
Im attaching file for better explanation
regards
  • Problem Sort Data by Sum of Total Amount.xlsx
Not sure what you are looking for is easy without helper cells :(
For unsorted result:
This will give you unique list, in cell A11:
=IFERROR(INDEX($A$2:$A$8,MATCH(0,COUNTIF($A$10:A10,$A$2:$A$8),0)),"")
with Ctrl+Shift+Enter
This in B11:
=SUMIF($A$2:$A$8,A11,$B$2:$B$8)
Copy down both
Hello thanks Khalid for the post but I need the highest for the total amount based on names, sorry if I not clear in the first place, For Narayan you're the man bro, that's exactly that I need.
Thanks Khalid and Narayan, God Bless you all
Hi Prasad ,
In that case , I doubt that it could be done without using a helper column , since the SUMIF by itself will handle only the numeric data , and the name data cannot be incorporated ; if a FREQUENCY function could be used , so that the name totals are only associated with the first occurrence of each name , that would work , but off-hand I cannot think of the resulting formula.
Perhaps Narayan is right, though it sounds like a nice challenge!
Would it be possible to have some updated sample data on which to test solutions?
Knowing you I am sure you will soon post a solution !
The worst-case scenario would be if all of them had the same scores total.
Of course , we can add more names and scores to see how the lower ranks would be handled.
