I have created some code to convert code from text to numbers. I run the code without any issues however after saving and closing the file an VBA changes that were implemented by the code are not saved??? This also happens after manual deletion of rows. I delete the rows, save the workbook and close it, only to find upon re-opening that the changes have not been saved???
Code as follows;
Sub ConvertToNumbers()
Do Until ActiveCell.Value = ""
ActiveCell.Value = CLng(ActiveCell.Value)
Loop
ActiveWorkbook.Save
Code as follows;
Loop
ActiveWorkbook.Save
