Problem with wildcards
govi
I us this code to mail clients with a maximum of 5 attachments.
The paths to the the attachments are in range R1:V1
I need to use a wildcard because the attached files can be any extension.
The paths I use now are:
G:\AHC\01. AHB Primair Proces\05. Teammappen\03. Team CCH PP\1b. AutoInvoerInsite\SlaHierBestandMailOp\3059380_1.???
G:\AHC\01. AHB Primair Proces\05. Teammappen\03. Team CCH PP\1b. AutoInvoerInsite\SlaHierBestandMailOp\3059380_5.???
But when I run the code I get this message:
"File -or Foldername is invalid"
Can someone help please?!
Thanks govi
Sub Send_FilesGEA()
'Working in Excel 2000-2013
'For Tips see: http://www.rondebruin.nl/win/winmail/Outlook/tips.htm
  Dim OutApp As Object
  Dim OutMail As Object
  Dim sh As Worksheet
  Dim cell As Range
  Dim FileCell As Range
  Dim rng As Range
  With Application
  .EnableEvents = False
  .ScreenUpdating = False
  Set sh = Sheets("mail")
  For Each cell In sh.Columns("F").Cells.SpecialCells(xlCellTypeConstants)
  'Enter the path/file names in the C:Z column in each row
  Set rng = sh.Cells(cell.Row, 1).Range("R1:V1")
  If cell.Value Like "?*@?*.?*" And _
  Application.WorksheetFunction.CountA(rng) > 0 Then
  With OutMail
  .to = "info@mail.nl"
  .Subject = "" & cell.Offset(0, 17).Value
  .Body = "" & cell.Offset(0, 19).Value
  For Each FileCell In rng.SpecialCells(xlCellTypeConstants)
  If Trim(FileCell) <> "" Then
  If Dir(FileCell.Value) <> "" Then
  .Attachments.Add FileCell.Value
  Next FileCell
  .Display  'Or use .Display
  Set OutMail = Nothing
  Next cell
  Set OutApp = Nothing
  With Application
  .EnableEvents = True
  .ScreenUpdating = True
These are standard way to mark a path.
Dim path As String, mypath As String
path = "G:\AHC\01. AHB Primair Proces\05. Teammappen\03. Team CCH PP\1b. AutoInvoerInsite\SlaHierBestandMailOp\3059380_1.*"
mypath = "G:\AHC\01. AHB Primair Proces\05. Teammappen\03. Team CCH PP\1b. AutoInvoerInsite\SlaHierBestandMailOp\" & Dir(path)
