Problems positioning UserForm
Hello again,
I had this working before but, for some reason I messed it up. I have a UserForm called "New_Line_Insert" and I'm trying to get it near the top right hand side of the screen.
I have the following code in my 'ThisWorkbook'
Private Sub UserForm_Activate()
    With New_Line_Insert
        .Top = Application.Top + 1025 '< change 125 to what u want
        .Left = Application.Left + 2025 '< change 25 to what u want
No good, I've tried:
    With UserForm
I've also put these Codes on mySheet4 Object where it is supposed to be working!!
The Userform is appearing but it is in the middle to the Left of the screen??
Hello again,
    With UserForm
The code should be in the userform module, not ThisWorkbook, and you should use:
With Me
rather than:
With Userform
Hi, FranktheBank!
Glad you solved it. Thanks for your feedback and welcome back whenever needed or wanted.
Regards!
I'm back!! I thought it was solved but all that happened was the Box moved to the top and it didn't and won't go to the right!! Here's what I have in it's completeness:
In ThisWorkbook
Private Sub Workbook_Open()
    New_Line_Insert.Show
This allows users to Open UserForm.
In Userform
Private Sub New_Line_Insert_Click()
    NextRow = ActiveCell.Row + 1
    Dim r As Range
    Const myPass As String = "Assumption" 'Allows Protected Sheet to be unlocked to insert Rows
    Set r = ActiveCell
       With ActiveSheet
        .Unprotect myPass
        r.EntireRow.Copy
        r.Offset(1).EntireRow.Insert shift:=xlDown
        'Clear constants
            If Range("C" & NextRow) = 0 Then
        r.Offset(1).EntireRow.SpecialCells(xlCellTypeConstants).ClearContents
        .Protect myPass
    Cells(NextRow, 3).Select
This unlock Worksheet and Insert Row and Clear Contents
In Module1
Sub New_Line_Activate()
    Private Sub New_Line_Insert_Activate()
    With UserForm
        .Top = Application.Top + 125 '< change 125 to what u want
        .Left = Application.Left + 425 '< change 25 to what u want
The first part is duplication to 'Start' the UserForm but the Second is supposed to position the Userform.
My Userform is Named: New_Line_Insert, sorry I can't link pictures
