JK2900
So I have a strange problem:
My macro exports 2 PDF files to a specific folder and they look perfect on the screen!
However, when I print them the graph looks different. I'll display a picture of "right and wrong" below along with my code.
BONUS POINTS!!!
I also have a problem when printing this graph from excel (by selecting print area and clicking print). I've attached that picture as well (It shades under the curve).
But when I manually export it to a PDF and Print, it works....
Anyone have any idea why Excel hates me right now?
Thanks,
JK
Function GetFolder(strPath As String) As String
Dim fldr As FileDialog
Dim sItem As String
Set fldr = Application.FileDialog(msoFileDialogFolderPicker)
With fldr
.Title = "Select a Folder"
.AllowMultiSelect = False
.InitialFileName = strPath
If .Show <> -1 Then GoTo NextCode
sItem = .SelectedItems(1)
NextCode:
GetFolder = sItem
Set fldr = Nothing
End Function
Sub PrintToFile()
Dim fp As String
Dim Active As Worksheet
Dim path As String
Dim filename As String
'Uses GetFolder Function to open file browser
Worksheets("GraphData").Range("R2").FormulaR1C1 = GetFolder("C:\TEST_INITIAL\")
path = Worksheets("GraphData").Range("R2")
filename = Worksheets("GraphData").Range("R3")
fp = path & "\" & filename
'Print Trajectory
Sheets("GraphData").Activate
ActiveSheet.PageSetup.PrintArea = "$K$7:$Z$49"
ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF, filename:=fp, Quality:=xlQualityStandard, IncludeDocProperties:=True, IgnorePrintAreas:=False, OpenAfterPublish:=False
'Print Well Bore
filenametwo = Worksheets("GraphData").Range("R4")
fpp = path & "\" & filenametwo
ActiveSheet.PageSetup.PrintArea = "$J$51:$AA$95"
ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF, filename:=fpp, Quality:=xlQualityStandard, IncludeDocProperties:=True, IgnorePrintAreas:=False, OpenAfterPublish:=False
BONUS POINTS!!!
Thanks,
JK
