proceeding with color
Lawrence429
Hi all --
I am trying to develop a chart to follow process on various projects. I would like to put a % complete in column K and have columns A - J either red for % incomplete or green for % completed. So if the project is 75% complete, the first 7 columns would be green and the remaining 3 would be red, if only 10% is complete, column A would be green and the rest red. See the attached example (without any coding).
thanks for your help
Lawrence
PS I am not that good with VBA so if we could stick with formulas that would be great, if VBA is necessary please be detailed.
  • 999 color growth.xlsx
Hi and welcome to the forum :)
Something like this perhaps (attached)
EDIT: had to re-upload the file
Another option without helper,
1] Fill A2:J4 cells background color with "red"
2] In A2 >> Conditional Formatting >> Use a formula >> formula :
=COLUMNS($A1:A1)*10<=FLOOR($K2,10)
>> Format >> choose cell background color "green" >> OK
Copy across to J2 and all copy down.
Bosco
  • 999 color growth(1).xlsx
Thank you PCosta87 and Bosco_Yip:)
PCosta87, could you please explain the the equation. J$1 is empty so I don't understand how that changes color of the cell.
It is not empty... the 1st row has values from 10-100 (it serves as a helper row which you can avoid completely by going with @bosco_yip's solution).
The text is painted white so it seems empty but if you select J1 you will notice that, in the formula bar up top, the value is in fact 100.
