Hello Friend, I am using excel 2007. I stuck up in subject matter.
I have List of group name in column "A". It may be single (First) name and also double name (First name & Surname)
I required output result in column "B"
>Suppose within range in "A2" is "mack" then output required in "B2" "Mack"
>In same range in "A6" if name comes "Mack Lee" then output required in "B6" as oppsite name as"Lee".
I try out with formula "INDEX", "MATCH", "COUNTIF" but required result not get it.
In this matter if you give any suggestion, you are welcome.
I have attach file with required result.
