Remove Listbox item if match not found in VBA
Hello
I am writing vba code that will search all listbox items against a entire column in a sheet.
If listbox item not found in Excel sheet column, i want to delete the item from list. I tried few codes, its showing some error as "Could not get list property, Invalid property array index". Below is my code i am using currently.
Dim itemExistResults As Boolean
Dim myarray()
Dim intItem As Long
myarray = Application.Transpose(Sheet1.Range("a2:a1000"))
For intItem = 0 To ListBox1.ListCount - 1
    If IsInArray(ListBox1.List(intItem), myarray) Then
    ListBox1.RemoveItem intItem
Function IsInArray(stringToBeFound As String, arr As Variant) As Boolean
    IsInArray = UBound(Filter(arr, stringToBeFound)) > -1
End Function
I have attached my file for reference. In my file, if button clicked, it will open userform, there we can see list box which is loaded from sheet2. Once i clicked button it should remove all items which is not exist in Sheet1 A column.
Any assistance would be great.
  • Chandoo.xls
Why not search and remove the item as the list box's list is being added
Thanks Hui for reply.
I made it working by changing loop
For intItem = ListBox1.ListCount  To 0  step - 1
   EndIf
