Removing #NUM error when using array formula
LckySevan
I have the following array forumula:
=INDEX($A$1:$B$251, SMALL(IF($A$1:$A$251="amy",ROW($A$1:$A$251)),ROW(4:4)),2)
I want to remove the #NUM! errors from my list, I've attempted to construct a IF(ISERROR) condition but have been unsuccessful. Any advice would be appreciated.
Hi
For Excel 2007 and later, try this array formula(Validate by Ctrl Shift Enter)
=IFERROR(INDEX($A$1:$B$251, SMALL(IF($A$1:$A$251="amy",ROW($A$1:$A$251)),ROW(4:4)),2),"")
Sorry, I forgot to mention that I have excel 2003. I still tried the formula above just in case I was lucky, but it didn't work.
Hi, LckySevan!
Try this:
=IF(ISERROR(INDEX($A$1:$B$251, SMALL(IF($A$1:$A$251="amy",ROW($A$1:$A$251)),ROW(4:4)),2)),"",INDEX($A$1:$B$251, SMALL(IF($A$1:$A$251="amy",ROW($A$1:$A$251)),ROW(4:4)),2))
Still array formula so enter it with Ctrl-Shift-Enter instead of Enter.
Regards!
Hi, LckySevan!
Glad you solved it. Thanks for your feedback and welcome back whenever needed or wanted.
Regards!
