Hi
Can you please help to find what error with the code have below;
error msg:
Runtime error 424: Object required
error msg:
Dim PPApp As PowerPoint.Application
Dim PPPres As PowerPoint.Presentation
Dim PPSlide As PowerPoint.Slide
' Make sure a range is selected
If Not TypeName(Selection) = "Range" Then
MsgBox "Please select a worksheet range and try again.", vbExclamation, _
"No Range Selected"
' Reference existing instance of PowerPoint
Set PPApp = GetObject(, "Powerpoint.Application")
' Reference active presentation
Set PPPres = PPApp.ActivePresentation
PPApp.ActiveWindow.ViewType = ppViewSlide
' Reference active slide
Set PPSlide = PPPres.Slides(PPApp.ActiveWindow.Selection.SlideRange.SlideIndex)
' Copy the range as a piicture
Selection.CopyPicture Appearance:=xlScreen, _
Format:=xlPicture
' Paste the range
PPSlide.Shapes.Paste.Select
' Align the pasted range
PPApp.ActiveWindow.Selection.ShapeRange.Align msoAlignCenters, True
PPApp.ActiveWindow.Selection.ShapeRange.Align msoAlignMiddles, True
' Clean up
Set PPSlide = Nothing
Set PPPres = Nothing
Set PPApp = Nothing
