    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Same macro to run in multiple worksheets
Discussion in 'VBA Macros' started by Jared Li, Apr 21, 2017.
  1. Jared Li
    Jared Li New Member
    20
    Dear Experts,
    I have a set of data in three worksheets and the macro i am using should run in three worksheets at a time from a single macro button in Sheet 1.
    The data that I have needs to be extracted from Column 3 and separate the values in () in Column 4 and the values in [] in column 5 and at the same time Column 3 needs to be refreshed and shown without the separated values and that should happen in every worksheets at the same time.
    The expected result in Sheet1 should be:
    PO Number CUSTOMER NAME ORDER DETAILS () [] QUANTITY INSPECTED
    139778 ATLAS ASDLO**** PERKG FISH 23 YES
    139779 NANDOS ASDLO**** PERKTN MEAT 55 NO
    139780 ATTRONS ASDLO**** PERKG POULTRY 44 YES
    139781 VIDVEST ASDLO**** PERKG FISH 33 NO
    139782 LORENZO ASDLO**** PERKG FISH 22 YES
    So would other worksheets be like this as well.
    I have cross posted this at:
    https://www.excelforum.com/excel-pr...o-run-in-multiple-worksheets.html#post4634337
    But haven't been able to solve it. I have attached the file here so that You can see it and give me a solution. Thank You All.
  2. SirJB7
    SirJB7 Excel Rōnin
    8,883
    Hi, Jared Li!
    Thanks for the notice about crossposting, please update both threads when you find a solution.
    First of all, a block "With ws ... End With" is missing into the "For... Next" loop.
    Next, range Replace method doesn't accept wildcards so you should change your approach.
    Regards!
    Jared Li likes this.
  3. Monty
    Monty Well-Known Member
    802
    Hello Jared Li
    Could not get a chance to look at your code as unable to download the file..but what i can understand is you wanted to run the same macro in the three sheets.
    Try this.
    Code (vb):
    Sub test()
    dim ws as worksheet
    For each ws in workbooks.sheets
    < Your code goes here>
    next ws
    End sub
  4. Monty
    802
    Small change!
    Code (vb):
    Sub test()
    dim ws as worksheet
    For each ws in Activeworkbooks.sheets
    next ws
    End sub
  5. Jared Li
    Jared Li New Member
    20
    Thanks Monty, its not working unfortunately. I am posting my code here so that you can quickly look at the problem:
    Sub test()
    Dim ws As Worksheet
    For Each ws In Activeworkbooks.Sheets
    .Columns(3).Copy Columns("d:e")
    .Columns(3).Replace "(*)", "", 2
    .Columns(3).Replace "[*]", "", 2
    .Columns(4).Replace "*(", "", 2
    .Columns(4).Replace ")*", "", 2
    .Columns(5).Replace "*[", "", 2
    .Columns(5).Replace "]*", "", 2
    Next ws
  6. Monty
    802
    Try this!
    Code (vb):
    Sub test()
    Dim ws As Worksheet
    For Each ws In ActiveWorkbook.Sheets
    ActiveSheet.Columns(3).Copy Columns("d:e")
    ActiveSheet.Columns(3).Replace "(*)", "", 2
    ActiveSheet.Columns(3).Replace "[*]", "", 2
    ActiveSheet.Columns(4).Replace "*(", "", 2
    ActiveSheet.Columns(4).Replace ")*", "", 2
    ActiveSheet.Columns(5).Replace "*[", "", 2
    ActiveSheet.Columns(5).Replace "]*", "", 2
    Next ws
  7. Monty
    802
    If you want avoid any particular sheet where you do not want to run the macro please check below code.
    Code (vb):
    Sub test()
    Dim ws As Worksheet
    If ws.Name <> "Mainsheet" Then
    Next ws
    Still any challenges..let me know happy to help you.
    Monty!
  8. Monty
    802
    Just to remind you...this code start working in all the sheets available in your activeworkbook expect sheet name called ""Mainsheet" as an example.
    Monty!
  9. Jared Li
    Jared Li New Member
    20
    Monty it is just taking off the values inside the parentheses in column C and copying the same to column D and E and unfortunately not changing anything in sheet 2 and sheet 3.
    All I need is take off the values inside first parenthesis () in column D and third parenthesis [] in column C and show Column C without the separated values which is okay now and do the same to other worksheets. Can it be done?
  10. Monty
    802
    Jared Li
    I really don't know what your macro does...just concentrated on how to run the same macro in all sheets!
    Monty!
  11. Monty
    802
    Hello.
    Finally able to download your file..
    I think no macro is required for this..i just done with a simple formula...check if it works.
    Monty!
  12. Jared Li
    Jared Li New Member
    20
    Well I am a novice here and looking for your expert solution. I am attaching the file again if you can open it.
  13. Jared Li
    Jared Li New Member
    20
    There would be thousands of rows and many worksheets full of complicated order information so what i need is to cut the information down to minimum. And it is quite impossible to go through every sheet and edit the order information. i was using this formula but my boss wanted me to get some kind of trick so that it is done automatically.
  14. Monty
    802
    Hey
    Try this...Just click on the button.
    Am sure your boss must be happy now!
  15. Jared Li
    Jared Li New Member
    20
    Thats awesome Monty, u rock. One last thing, if somebody clicks on the button twice, it would be a disastrous. It just copies the whole values in Column C twice to other sheets. can that be checked? I am happy enough with the solution though. thanks mate. Cheers!!
  16. Monty
    802
    Jared Li
    That usually happens with any macro...when you run for the second time...So need to ensure.
    Monty!
  17. Jared Li
    Jared Li New Member
    20
    Thanks mate. You've made my life easier. Cheers!
    Monty likes this.
  18. Monty
    802
    Jared Li
    But quite interesting question how to stop somebody to click only onces?
  19. Jared Li
    Jared Li New Member
    20
    Yeah mate :D
  20. Monty
    802
    Am happy that it was helpful.
    Please let me know any future challenges...Happy to help you!
  21. Jared Li
    Jared Li New Member
    20
    Thanks Monty. You've been really helpful :).
  22. SirJB7
    SirJB7 Excel Rōnin
    8,883
    Hi, Monty, Jared Li!
    A suggestion without any intend to get my hands dirty on this.
    Why not filtering first column C containing "(" and then applying the actual process to the filtered rows? Then you'd be able to put a Maneki-neko near the keyboard and get the button clicked the whole day without any issue.
    Regards!
    PS: Just in case...
    https://en.wikipedia.org/wiki/Maneki-neko
  23. Monty
    802
    Sir.
    No words for your expertise..
    Really a good one!
    Monty!
  24. Jared Li
    Jared Li New Member
    20
    Thanks, haven't got that though.
  25. SirJB7
    SirJB7 Excel Rōnin
    8,883
    Thank to both of you but before agreeing with you I'd like to know, Jared Li:
    a) how many worksheets would the workbook contain?
    b) how many rows (average) would each worksheet have?
    c) how frequently are you going to add new worksheets or rows?
    d) how frequently are you going to emulate a Maneki-neko?
    Maybe after these clarifications I'd return to my still dumb behavior.
    Regards!
Share This Page
