Selection.fillleft not working
zohaib
I record a Macro in excel and below are the results. I don't know why the code doesn't perform the steps "Selection.FillLeft". I ran the macro in debug and when it gets to Selection.FillLeft it does not do anything and keeps going down the code and starts working again from "Range("A1").Select". How do I make Selection.fillleft work?
I have also uploaded a file that contains the raw data and sheet2 shows how the final results should look. thanks
Sub Macro20()
' Macro20 Macro
  Cells.Select
  Cells.EntireColumn.AutoFit
  Selection.AutoFilter
  ActiveSheet.Range("$A$1:$F$400").AutoFilter Field:=2, Criteria1:= _
  "Claims Imported"
  Range("B1").Select
  Selection.End(xlDown).Select
  Range(Selection, Selection.End(xlUp)).Select
  Selection.FillLeft
  Range("C1").Select
  Selection.FillLeft
  Range("D1").Select
  Selection.FillLeft
  Range("D1").Select
  Range("A1").Select
  Cells.Select
  ActiveSheet.Range("$A$1:$F$400").AutoFilter Field:=1, Criteria1:=Array( _
  "AHH", "AMM", _
  "ASJ", _
  "ASL", _
  "AWB", "Charges On Multiple Forms", _
  "Claims Imported", "Claims Not Imported", "HIS Download Totals"), Operator:= _
  xlFilterValues
  Range("J49").Select
  • Book8.xlsm
Your code is not working because the FillLeft method expects a multi-column range ; given a single-column range , it will do nothing.
See the attached file for the revised code.
  • Copy of Book8.xlsm
