sequential order and display functions required.
tango
Please help me to find a solution to my requirements: Basically, I am needing of two functions
1) Function 1 is to make a sequential list based on the ID number. It starts as "Attachment0" onwards (from Attachment0 to Attachment30).
If number column has a similar value then 'attach' columns shows sequential order (from Attachment0 to Attachment30) otherwise just Attachment0
2) Function 2 is to display the "file name" cell value in its "AttachmentX" columns based on the "Attach" column.
Hope the attached sample explain it better. Please and thank you in advance.
  • freelancer-excel-1.xlsx
I am not sure what you mean by function ; see the attached file for formulae which do what you want.
Big Thanks Narayanan. You got it right.. By the way, is there a way to have the result all in one row (see sample attached). result could be put in another worksheet or somewhere.
  • freelancer-excel-1 (2).xlsx
