Sharing Excel & Using Textboxes
Kevin Briere
I know that the textbox feature is turned off when sharing an Excel file. I'm just wondering if there is anyway to overcome that.
I inserted an Textbox (activex control) an excel file and saved and shared, (although none opened at the same time). I was able to use the textbox as normal without any issue or blocked.
Not sure what is your question/challenge.
Prasad DN
I do thave an issue where I cannot edit a shared workbook textbox. Uploading an excel.
  • Book1.xls
Sorry, I was thinking you were taking about Textbox from developer tool. Your file shows its a shape object.
Yes, I see the challenge.
Prasad DN
PS: Could not find any workaround.
